Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-27-2008, 01:27 PM
davecrzy davecrzy is offline
92 Wil Not Start!
I have a 92 saturn SL1 SOHC Throttle body and it will not start! It has spark and is getting fuel to the throttle body but not through the injector. I have replaced the following:
*Fuel pump
*Fuel Filter
*Crank position sensor
*Air intake sensor
*Throttle position sensor
*Fuel injector
*Pressure Regulator
-The ignition module is good (checked @ autozone)
-ALL fuses are good, checked and rechecked
-Enough fuel pressure at carb
-Starts with Starting fluid, but dies out
Please help
Thanks
Old 07-27-2008, 05:20 PM
RC1488 RC1488 is offline
Re: 92 Wil Not Start!
Again check the injector. If your have fuel all the way to that point, im sure its your issue. Also check the connector.
Replace your ECTS also. This sensor is vital to air/fuel ratios at start up. Replace the one with the 2-wire connector
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 07-28-2008, 09:39 AM
ok, now after i posted my problem, i went out and tinkered some more. There is fuel getting to the injector, u can see it coming out as it cranks. It will crank and start then as soon as it does it will die. What is the ECTS? There is a part on the throttle body at the point of where the cable is @ that is called Idle Air Control Valve, it has 4 wires going to it, i took it off anc cleaned it but still looks crappy. would this be a problem? This saturn does not have injectors at the pistons, only one at the throttle body.
Thanks
David
Old 07-28-2008, 11:41 PM
Yes you have a TBI engine. Regardless your Engine Coolant Temperature Sensor needs to be replaced. This controls fuel/air mixtures during start up. Yours is cracked. use the search button for a video ive posted on how to replace it. Your local dealer has them in stock. Be sure to check the connecot for corrosion and clean/repalce it as needed.
Any SES Light?
Old 07-30-2008, 07:01 PM
which temp sensor do i replace? there is 2. one goes to computer and other goes to guage. there is a single green wire on one and two on the other(1 black,1 yellow). i know they are inexpensive but every penny counts now-a- days. (why cant these cars be like the old days?)
once again, thanks.
Old 07-30-2008, 10:42 PM
Ahh Sorry, i didnt mention which one. You need to replace the one with the 2 wire connector. This is the one used by the PCM. The other one rarely cracks and should be fine
Old 08-01-2008, 10:14 AM
well the temp sensor is good now. Car still not running . I thhink it thought about staying running for a minute, but died. Any More ideas ?
Think alternator? Battery is dying out now from starting so much!
