Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-27-2008, 12:47 PM
Sotocreations3 Sotocreations3 is offline
Question The Push Starting Woes need help to fix problem
I have a 95 Gsx, a few months ago this problem started slowly it would start when you pressed the gas pedal to W.O.T. and give it 5 or 10 seconds to start but now it has gotten worse no matter what i do it will not start the engine turns over and trys to start but wont UNLESS you push start it, when you do that it start and runs good Here are somethings i have checked.
Hooked Up Vacuum Gauge- Reads 0hg when cranking
made boost leak detecter- checked and fixed all leaks (just waiting on new seals for throttle shaft)
Hooked up Scanner- only code it has is P0443 which is emission and i have the new part for that
compression checked-good on all cylinders
fuel pressure checked- at 38psi when trying to start
spark checked- good spark all cylinders
Its had a full Tune-up new ngk plugs new magstar wires new pcv valve it has a aem air filter the and the oil was changed last month
It also has a new alternator a new starter and a new battery with new cables
Some Engine Info- the engine was blown when i got the car so i took it to a engine shop that does imports they rebuilt it so now it has Wiseco Pistons Eagle Connecting Rods and did the balance shaft eliminator the engine is about a year old now.
SO CAN ANYONE HELP ME FIND OUT WHY IT WONT START????
Old 07-27-2008, 01:26 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: The Push Starting Woes need help to fix problem
Welcome to AF!
Not real sure what to say about your car. Sounds like you have checked everything out. Maybe it could be the ECU.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-27-2008, 03:26 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Wow... That certainly is the strangest problem I have heard in a long time. It doesn't make sense that it won't start unless you push start it. The only thing I can think of is that it could be a problem between your ignition and ECU possibly... Especially since everything else seems to check out ok.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-30-2008, 05:01 PM
Luckly me i have 2 95 ecus and have tried both.
