Old 07-27-2008, 11:54 AM
Veyron's Avatar
Veyron Veyron is offline
Ferrari F430 Scuderia
This is Fujimi's new kit of one of my favorite cars. I never liked the 430 styling much...the 'shark' openings in the front looked great on the race version but not on the road car IMO. Then comes the Scud with the new shaped front grilles and a very racy rear design which I love and one of the coolest interiors ever.
On to the kit.
Fujimi did a good job capturing the Scud vs 430 differences although as mentioned on AF previously the side skirts are a bit too short, to remedy this I clipped a couple part number tabs from a sprue and glued then flat against the front of the skirts to extend them. Next I sanded them to the correct length and molded them in with superglue. I didn't do such a great job in that process which is actually easy to do...but I'm less focused in my building these days for some reason. There are separate parts for the front side heat extractors I glued in then molded in.
Another part that needs correcting to replicate the Scud is the rear window. The Scud does not have defroster elements embedded in the glass so I suppose there are two options to fix this. One is to sand the defroster off the kit 'glass' then polish it out, or the method I used which was to use the kit window as a template then cut a new one from acetate. Not too hard to do although you might have to make 2-3 until you get the fit acceptable. Fujimi's adhesive on their window mask is strong enough to lift a piano so I couldn't use it on the fragile acetate. To get your black trim on it I used a marker around the edges.
Also as previously mentioned the window masks Fujimi provides are not pre-cut so you have to cut along the lines they printed on the material as accurate as you can...and their adhesive is so aggressive if you have to lift off to reposition any of the masks it stretches them out shape terribly.
The interior is fantastic and includes some of the best looking seats ever in a kit. The interior is like a model unto itself...the real car has carbon fiber throughout(as well as the engine bay) so you can learn to master CF decals or take the easy way out like I did. I did a lot of experimenting with trying to get a CF look with various painting methods. One process I like a lot is to spray Testors lacquer spray window tinting(which is black unlike Tamiya's Smoke) over metalizers and/or metallic silver or grays. You can use different base coat colors to get the tint you need for the other base colors you are using on the body and interior etc. My car is painted with Grigio Titanio which is a bluish tinted metallic gray so my base metalizer was Anodonic Gray which is on the cool end of the color spectrum. The more coats of window tint you apply the darker your parts will get...don't get them so dark that you can't see the base metallics reflecting through. The main interior color is a mix of some Acryl blues and gray.
The Cobra Colors Grigio Titanio on the body was top coated with TS13 and polished. I did not clear over the stripes as they are on the real car but they look fine. The front ones are barely long enough but I had to shorten the roof and rear stripes a bit. I put a strip of 1/8" wide tape beginning on top of the location for the front Ferrari emblem(used as the center of the car) then across the roof and to the rear of the car. I lined the tape up as good as I could in the center of the body and used it as a guide to get my stripes spaced correctly and straight. The Scud has a Ferrari script just below the rear window so on the model it has to go over the stripes. If you do not clear over the stripes it's difficult to get a good script on the car..by that I mean a transfer would be preferable but because they have adhesive on them you can't press them on the pull the backing off without pulling off the stripes. I tried removing the backing form the transfer and then sticking it on but the transfer is too fragile to be handled in this manner. I ended up using a photo etched script there.
All Scuds have CF side mirrors, I did mine body color.
I painted the rims with Gunze Stainless lacquer metalizer and put a MSM peel and stick emblem in the center, their emblems were also used on the body. The calipers are painted with TS16 and are a very fiddly part of the kit. The disc are Coated with Testors Gunmetal metalizer which I also used on all the body grille meshes. The real car used a darkish gray color for the grilles. I used the metalizer because the metallic in it gives it a nice 'mesh' effect...especially on the rear lower grille which is noe an open mesh part. I cut the rear upper grille out and replaced it with Tamiya's mesh material which was alo sprayed with the Gunmetal metalizer to match. Cutting the upper grille open is very worthwhile though it takes a bit of time it's a great effect on the model.
Old 07-27-2008, 12:21 PM
stevenoble's Avatar
Re: Ferrari F430 Scuderia
Really nice finish and nice colour!! I have just received mine from HLJ I hope when I build it it turns out as nice as yours.
Steve Noble
Old 07-27-2008, 12:25 PM
The Modeler's Avatar
The Modeler The Modeler is offline
great job! Fantastic!
www.Automodelismo24.com
The big models are born from small details
Old 07-27-2008, 12:47 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Looks great! Wish I could do quick yet stunning builds like you can.
Old 07-27-2008, 01:53 PM
73superduty's Avatar
73superduty 73superduty is offline
Lost in plastic
That is a stunning build and beautiful car. You always have a clean way about your builds. Particularly your clean lines when it comes to the black window trim.
Can you explain your methods for such clean lines on that? What type of tape, paint, brush(if you use a brush what type) or spray? It's one area I need to work on.
Great work!
Chris
Old 07-27-2008, 02:12 PM
Veyron's Avatar
Great work!
Chris
Thanks all!
Chris, here's a link to a tutorial I made a while back. I still do it this way.
http://www.automotiveforums.com/vbulletin/t93656.html
Old 07-27-2008, 03:49 PM
godfather23's Avatar
godfather23 godfather23 is offline
Very inspiring. Fantatic work and as usual great photography. And a big thanks for sharing such a useful introduction on the kit and your work. This will be very helpful when I choose to build oe of these my own - one very distant day in the future.
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 07-27-2008, 04:38 PM
MinesGTR MinesGTR is offline
its nice ; i like it so much ; my next plastic kit will fujimi scuderia
Old 07-27-2008, 05:29 PM
Lost in plastic
Originally Posted by Veyron
Thanks all!
Excellent tutorial! Thank You! I will definitely try that out on my next project. I would have never thought it would be so easy!
Chris
Old 07-27-2008, 06:16 PM
tonioseven's Avatar
Another beautiful build from you!! I love the paint/stripe combo!!
Old 07-27-2008, 07:59 PM
robrex's Avatar
robrex robrex is offline
Wow! that first picture is fantastic! I love the colour!
Rob
Old 07-27-2008, 08:49 PM
tuned.by.twenty's Avatar
tuned.by.twenty tuned.by.twenty is offline
AF Vendor-TBT's Owner
Gorgeous model. I was never really interested in the F430 either, until the Scuderia came along. You did the kit justice.
Old 07-27-2008, 09:14 PM
dmacb's Avatar
dmacb dmacb is offline
Lovely build. You sure did your homework.
Old 07-27-2008, 10:05 PM
Lownslow's Avatar
Lownslow Lownslow is offline
nice nice
Old 07-27-2008, 11:04 PM
klutz_100's Avatar
Outstanding build - even by your high standards
