Old 07-27-2008, 12:54 AM
chrissbee77 chrissbee77 is offline
Angry SeaFoam
I have a 2001 grand prix gt 3.8 non supercharged and was wanting to run a bottle of seafoam through the engine. can ANYBODY send me a pic of a good place to run i. One opinion is listed below let me know what to do thanks everyone.
Your car has multi-port injection, and the upper plenum is air only. DO NOT pour the seafoam into your throttle body, they are referring to old TBI units, not MPI. Put it in the tank as you fill up, that way it gets mixed up thoroughly.
Old 07-28-2008, 01:08 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Re: SeaFoam
Just my opinion, but if it ain't broke........don't fix it. It most likely won't do any good and may even hurt it.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 07-28-2008, 08:23 AM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: SeaFoam
seafoam is great stuff. i divide the can into thirds and put 1/3 in the gas, 1/3 in the crankcase by way of the oil fill and the other third i put in through the big vacuum line off the brake booster. run the car until the white smoke stops then change the oil.. dont let the seafoam stay with the oil as it can damage the oil filter.
Old 07-28-2008, 08:29 AM
Highbeamz Highbeamz is offline
Re: SeaFoam
I have heard good things about seafoam but I have never used it myself. Of course I have heard stories of it taking out rings due to the carbon being broken loose and damaging them, but those cases are few and far between, if not coincidence.
I thought about running some through mine because it has a slight intermittent "Bump" (like a miss) at idle but EVERY car I have owned does that so I'm convinced it's normal.
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 07-28-2008, 11:31 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: SeaFoam
How many miles do you have and why? Any issues that warrant the service?
Running Seafoam through a tank gas will do nothing to get rid of the carbon buildup and crud in the UIM plenum and first part of the lower intake manifold runners and the throttle body. Via the gas tank probably good as a top engine cleaner to clean the fuel injectors, cylinder heads, valves and pistons but it will miss areas that should be cleaned like the intake system. Hopefully all the stuff blowing out doesn't damage or clog the CAT converter. However, since this is a Series II 3800 L36 engine susceptible to the infamous UIM gasket issue then I would exercise caution depending on the mileage especially if you plan to run it in via the throttle body. You don't need any chemicals to speed up gasket replacement or possibly damage the flaky gaskets.
However, GM has top engine cleaner that is safe to use.
Timeslip 08/12/06
AF Community Guidelines
Old 07-29-2008, 11:03 AM
Epicurus Epicurus is offline
Re: SeaFoam
I don't think I would pour Seafoam into my engine unless I felt I had a really good reason.
Has anyone ever heard of "steam cleaning" your engine? The process is done by pouring very small amounts of water into your throttle body and giving it some throttle. The idea is that the water will vaporize in your engine and the steam will help break up carbon deposits. I'm not really sure if this would be any better than Seafoam, though. What do you guys think?
Old 07-29-2008, 09:39 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: SeaFoam
Dont think it would work as it will get sucked into the cylinders. Probably isn't a very good idea.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
