Old 07-26-2008, 10:52 PM
klutz_100's Avatar
Ferrari 250TR by Hasegawa
The new Hasegawa 250TR
I am building this kit strictly OOB although the original Hassegawa photo etch wire wheels will be allowed since they do come in a box with the company logo on it
The first thing I did was, in retrospect, a mistake . At the time I hadn't made my decision for an OOB build and I removed the molded in mesh on the hood vent.
Now I am stuck with it but I am sure there is an original 250TR out there somewhere with an open vent just like this
Next thing I did was to tackle some of the body parts that need to be joined together. Hasegawa are really generous with this kit and they allow for a variety of versions with different scoop and hinge configurations.
However, one of the non-negotiable intakes is this one but they have still molded it as two pieces. This solution leaves an awful join line that needs to be puttied away (I don't know why they did it this way because I am pretty sure that modern injection molding technology would have permitted this to be made as one piece)
Another left-curve they throw at you is the join line between upper body part and the inside panel of the pontoon fender. This again leaves quite a substantial join line which could in fact be confused for a panel line. I have noticed that some modelers have in fact left this join line but my photo research shows that this is never present on the original cars.
It turned out to be a bit of a bear to fill. After several rounds of putty, sanding and primer, I was still getting a ghost line. On top of that, the putty tends to fill panel lines that should stay so they need to be carefully re-scribed. The photo below is from during that process and you can see that the line is still there. I finally got that sucker filled though...I hope.
The only part of the molding that I would criticize so far is the panel line around the gas filler tank. On my kit the line was so soft and shallow I was seriously worried that after paint it would barely be visible. For this reason I filled it in and re-scribed a new one.
Finally I added the airs scoops below the doors and re-primed. I think this part is finished now and just needs some minor tidying up.
Because I am like a child, I couldn't wait to assemble the Hasegawa P/E wheel set for this kit... so I assembled it
Beautiful wheels and well worth the money (although TBH I don't think that the original kit wheels look too bad either)
Finally I have started painting and dry-brushing the chassis and suspension parts to prepare for a ride height/track test fit.
I pre-shaded the seats before painting with Vallejo Fire Red over white primer. I am very happy with the subtle effect (although TBH I think I gave the seats one too many coats of paint and slightly killed the effect)
In the spirit of "nothing that wasn't in the box" I stretched some of the white sprue and added piping to the seats
Looks pretty good...
...but a couple of glitches.
The seats will now get a coat of Vallejo Satin clear to finish them off
I also stretched up a whole bunch of black sprue for plug wire
I made the plug wire tidys by making some thicker, tapered stretched sprue and then hollowing out the ends with progressively larger drill bits in the pin vice.
Next thing will be to wire the distributors.
This is how she is starting to look
Thanks for looking.
Old 07-26-2008, 11:08 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Re: Ferrari 250TR by Hasegawa
Always a joy to watch you build. Lovely work on a lovely car.
But I think you're stretching the definition of "out of the box".
Checked your PMs lately...?
PHOTOBUCKET SUCKS
Old 07-26-2008, 11:40 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Awesome start, Klutzie. Why impose the strict OOB limitation on yourself though?
Old 07-27-2008, 01:25 AM
klutz_100's Avatar
I'm assuming that the pun was intended, Andy?
Sh*t! AF is for crap lately!
I can hardly ever log on, I am not getting update notifications and to top it all, not only am I not getting email notifications about PMs but on the home page it's not even showing me that I have unread messages?!?!? Thanks for the heads up
Now, which moderator should I bitch about this to.....?
Alex, depends on how you define OOB?
My definition is "nothing that the manufacturer didn't include in the box". Now just wait and see LOL
More seriously, I don't want to spend any more money on this kit and I just want to see what I can do without after market parts. Just a different way of having fun with my models and I'll enjoy it just as much I think
Old 07-27-2008, 01:33 AM
klutz_100's Avatar
Distributors have been sprued wired
Old 07-27-2008, 04:04 AM
godfather23's Avatar
godfather23 godfather23 is offline
Hey Klutz, obviously we are on the same project as we speak.
Your seats look great. I subject that you just painted them (if so, what did you use?). Any thoughts on the paint - will it be a red one?
I was very disappointed on the paint guide. You chose right to paint the exhaust parts on the engine the same color as the actual exhaust is painted. I did them in silver and need to figure out a way to match the color differences later.
I´m looking forward on your progress and I admire your "sprue"-skills including the wiring technique. I should pick these up someday.
How are your overall thoughts on this kit?
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 07-27-2008, 04:57 AM
klutz_100's Avatar
Robert, I have nothing but praise for the kit so far (apart from that infamous joint line )
The seats were primed in white primer, I pre-shaded the creases with Vallejo Air Black and then painted with Vallejo Air Fire Red (IIRC). They will be getting a final cover of Vallejo Air Satin clear.
The white piping on the seats is stretched sprue fixed with dots of thin CA.
Hope that answers your question?
Old 07-27-2008, 06:34 AM
jano11 jano11 is offline
Looking good for a so called OOB build!
Let's see the rest of it now!
Old 07-27-2008, 09:06 PM
quadzero's Avatar
quadzero quadzero is offline
Holy moly what a beautiful car. I see you're up to your usual tricks again. Those seats are excellent, I'll never figure out how you put that sprue on so cleanly. Engine is fantastic, but usual for the gems the Klutz shack pumps out. Great start and already a great wip.
Old 07-27-2008, 10:52 PM
Mojo_stevo's Avatar
Mojo_stevo Mojo_stevo is offline
Klutz_100;
What method did you use to get such even stretching with the spruce?
Thanks,
Stephen
Old 07-27-2008, 11:34 PM
klutz_100's Avatar
Stephen, you should really ask Les (Quadzero) who posted just above you - HE"S the sprue king here on AF
TBH I am a terrible sprue stretcher - the technique has always eluded me however this time I got lucky (maybe Hasegawa plastic is more stretcher friendly?)
I just heated it over a tea warmer candle and pulled. On the occasions I managed to get a nice long 100cm piece of stretch, the thickness issue had kind of taken care of itself LOL
One thing I did notice was that it was best NOT to pull immediately after from removing form the heat source but to wait one short second and then begin a moderate and constant pull
Not surprisingly there is some minor variation in thickness between the ends and the middle of the stretch but we are talking 0.1mm over 50cms (I checked it with calipers) so in fact it is for all practical purposes unnoticeable.
HTH
Old 07-28-2008, 12:32 AM
quadzero's Avatar
Here is an excellent way to do it, borrowed from a great modeller here on the forum, who explains it well;
Originally Posted by willimo
I hold the sprue over a candle probably... 4-6 inches above the flame, and roll it between my fingers so that the flame heats the plastic evenly around the entire sprue. When the plastic starts to swell right above the flame, I get ready and at the instant that it begins to droop, I take it away from the flame while stretching it. I typically am stretching sprue just to use it to fill holes in the bumper of a kit or something, so I don't bother over uniform thickness and it's a very easy and quick process. To get the uniform thickness like was used above takes some practice; but basically you just don't pull as hard and the tricky part is keeping it straight while you do so.
Just practice a lot, lord knows if you're like me you've got more sprue than you could melt and stretch for the rest of your life.
Now, just to keep the glue nice and tidy on those seats and I'll really be on to something.
Old 07-28-2008, 12:42 AM
sportracer02's Avatar
Hi Steve,
nice job so far.
Seats look great with the white sprue, for engine-wiring I prefer wire
Micha
Old 07-28-2008, 04:01 AM
Mojo_stevo's Avatar
Thanks for the tips. Sound much more sound than my butane lighter technique . I'll give the tea light candle some practice.
Old 07-28-2008, 11:53 AM
klutz_100's Avatar
So do I but it's not allowed this time. "Nothing that wasn't in the box" are the self-imposed rules for this one
