Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 07-26-2008, 06:28 PM
metalgouger metalgouger is offline
1991 LeBaron, broken left front wheel stud
Howdy Folks,
Looking for insight for pulling the wheel hub for a 91 Lebaron because of a broken wheel stud.
The car is front wheel drive with disk brakes.
The wheel hub has a keeper covering the bolt which is cotter pin inplace.
I can see how to take it a part, but I need to know how to reset that hub bolt. is it torqued on to a certain setting? Is there anything else I should know before taking it a part?
Thanks for everything.
Sam
This place rocks for learning
Old 07-26-2008, 07:11 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: 1991 LeBaron, broken left front wheel stud
I would suggest replacing the entire hub if you're going to take it apart.
Old 07-26-2008, 07:17 PM
thanks for the reply..
can you give me some insight for taking it apart and what to expect?
Old 07-27-2008, 01:00 PM
Polygon's Avatar
The Red Baron
Well, that depends. Do you know if your car has pressed bearings or a bolt on hub bearing assembly?
Old 07-27-2008, 03:27 PM
Well here we go...
The hub is held on by a large gland nut then a spring washer, bolt keeper and finally a cotter pin. The book shows torque spec's of 180 foot pounds for resetting the hub.
Thats as much as I know at this point.
Thanks again
Sam
PS. this is my first front end on an American car. But I've done lots of work on Nissans and VW's
Once that gland nut is removed..do I need to use a slap hammer or puller for removing the hub?
Also... are these bearings sealed mech. or tappered bearings. I suspect it's gonna be a flat bearing because the gland nut is torqued on, but I thought I should ask.
Old 07-28-2008, 12:03 AM
Polygon's Avatar
The Red Baron
It sounds like you have a bolt in assembly. Once you remove the gland nut all that's holding the the HUB on are four bolts in the back of the knuckle. Also, make sure to support the axle.
Old 07-28-2008, 09:22 PM
Thanks so much for the info.
Anything else I should look for..
pitfalls... possible hang up spots.
Old 07-29-2008, 01:29 AM
Polygon's Avatar
The Red Baron
If you've removed a half shaft before it will be pretty straight forward.
Old 07-29-2008, 10:25 AM
Smile Re: 1991 LeBaron, broken left front wheel stud
Job is all done...
it all came apart nicely
repacked bearings
went back together without a hitch
Thanks so much for the support
Old 07-29-2008, 05:01 PM
Polygon's Avatar
The Red Baron
No problem. Glad to hear it went smoothly.
