Old 07-26-2008, 02:46 PM
tucsondirect tucsondirect is offline
94 Lesabre ignition problem
1st time i have had this problem, The key in the ignition will not come out, i havent run into this problem anywhere else.... By not come out i mean i cant get the key out of the run position (i can start it) but i cant turn the car off with out disconnecting the positive battery cable, i dont like doing this for several reasons 1. im worried about a voltage spike 2. its a pain in the butt 3 it looks like im trying to steal a car everytime i need to go somewhere that i cant get to on the atv
any idea whats wrong? (with the lock tumbler(
any idea how to fix (easy)
and how the heck do i get the sterring wheel off?
thanks!
~Lee
Old 07-26-2008, 04:36 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 Lesabre
If the key returns to the off position and it continues to run, usually the ign switch is bad or the rack/rod on the cylinder came loose or is out of adjustment. Good pics and break down at autozone.com, repair guides.
Old 07-26-2008, 05:40 PM
Re: 94 Lesabre
the key will not turn to the off pos. Can you get me a link i have looked on autozone and have had no luck thanks for the quick response
Old 07-26-2008, 06:01 PM
Blue Bowtie's Avatar
Registered Offender
Re: 94 Lesabre
Check the finger and sector assembly in the steering column. Evidently, the PARK gate is not open for the ignition lock cylinder finger to return to the LOCK position:
Can you shut the engine off in the NEUTRAL position?
This might also help:
Old 07-26-2008, 07:20 PM
Re: 94 Lesabre
wow thanks! that helps.... no the key will not turn when in neutral (where did u get those diagrams? do you have a paypal account so i can send you something for your time (dont have the cash right now but in a week or so...) also how do i get the steering wheel off? i have gotten the airbag off and i have removed the large nut in the middle but... i cant remove the steering wheel
edit.... IF it helps at all the steering wheel is not locked i can turn it freely and with the battery connected it wont shift unless i put the break on so that is working the way its supposed to
Old 07-27-2008, 02:21 PM
A990 racer
Re: 94 Lesabre
You need a wheel puller, based on your questions here I would suggest you may need some experienced help with this.
