Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 07-25-2008, 10:23 PM
goadster4 goadster4 is offline
Changing tire size
I have a 2002 Durango with 265/70R 16 on them. was considering going to a 265/75R 16. Is there any problems that might occur with this change? What can I expect to find different in the ride and the speedometer?
Old 07-28-2008, 10:22 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Changing tire size
Usually people want to go the other way, to a lower profile tire...your question is unique in that respect. Your speedometer will read slow. The -75 is the aspect ratio of the tire dimension...read as the percentage of the tread width (the 265 part of the size...in millimeters). A higher aspect ratio means a taller tire from the larger diameter, meaning a bigger circumference. Thus the tire doesn't have to rotate as much to travel the same distance. At that aspect ratio and the amount of the change, change in ride quality would be minimal...mostly softer and probably more wallowy (is that a real word?) since you have more sidewall to flex as you take bumps and curves.
If you wish to keep your speedo within calibration and stilll wanted to go to a taller tire, you would need to find a 245-75R16...slightly narrower. The narrower tread would lend to its own handling issues and possibly towing limits.
IMO, I'd reconsider the size change, but a little more info on why might make the justification. In any case, I hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-04-2009, 03:07 PM
mrsbb mrsbb is offline
I just put 265/75/16 on my durango and don't notice anything different with speed..check the inside of the driver door to see which size is recomended. Thats what I didi.
