Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-25-2008, 05:02 PM
navyboy85 navyboy85 is offline
oil leak
Hey just need some help i noticed today there was some oil on top of the head where the spark plug wires go in i have seen it there before but today i installed a boost controller it was at 9 psi before but i put it up to 12 psi and there is a little more i cleaned it and went and drove it then checked it again and there was some on it looks like it might be coming from one of the screws on top of the head how can i fix it or whats causeing the leak.
MHI Evo 3 16g (Ported + 34mm flapper),GT Manifold (Ported),GT 2G install kit,190lph Fuel Pump,Denso 550cc Fuel Injectors ,Injen Intake,K&N Filter,HKS SSQV BOV,SBR 2.5" S.S. with Dump O2 Housing (Ported),Full 5Zigen Exhaust,3in" Downpipe, short throw shifter, apexi 2 afc, big front mount intercooler. 12 psi boost.
Old 07-25-2008, 05:51 PM
Re: oil leak
Well i was cleaning the valve cover a noticed it was cracked around one of the screws that are by the spark plug wires this cant be good what can i do with this prob. someone help.
Old 07-25-2008, 06:23 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: oil leak
If the valve cover is cracked then you'll need to replace it with another one. When you put the replacement one on you'll have to be careful about tightening it down. If I remember correctly, you need to tighten them by staggering from one side to the other until they all have been tightened equally so you don't crack the next one. Don't overtighten either or they will crack. Just get em a hair past snug.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 07-25-2008, 06:32 PM
Re: oil leak
is there a way to seal the crack till i can replace it.
Old 07-25-2008, 06:51 PM
inafogg inafogg is offline
Re: oil leak
epoxy may work.there is no pressure so any good sealant may hold
Old 07-26-2008, 02:15 PM
Re: oil leak
just another quick ? how much boost can i put to the engine without blowing it up.
Old 07-27-2008, 02:26 AM
Re: oil leak
Well that depends on many things...
1. The integrity of the motor itself.
2. The size of your injectors and pump.
3. Your tuning capabilities.
It will vary for each motor and setup depending on all these combinations plus several other mods.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 07-27-2008, 07:20 PM
Re: oil leak
ok well stock internals i have 550cc injecters with a 190lph fuel pump and in my signature block is the rest of my mods also i just got in my apexi safc 2 im hooking it up soon what kind of senser does it have is it the karman or somthing else.
Old 07-27-2008, 10:18 PM
Re: oil leak
Yes, our cars use the Karman Vortex style of MAF's. Do you have a datalogger for doing this or are you going to be using the o2 voltage reading? I didn't see anything in your sig about that or a wideband. That is why I am wondering... You will need one or the other to properly tune it.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 07-28-2008, 03:26 AM
Re: oil leak
i dont have a data logger but i have a narrow band meter how hard will it be for me to tune with just using the narrow band i know i need to to get a wideband but just dont have the money right now.
Old 07-28-2008, 10:07 PM
Re: oil leak
Well, you can do the AFC blue wire mod, which will give you your o2 voltage on the AFC and you'll be able to halfway tune it like that. Certainly not the best way, but it'll work to an extent. I would definitely consider a wideband as one of your next few purchases before anything else...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
Old 07-29-2008, 04:17 PM
Re: oil leak
When u say the blue wire mod what do u mean how do i do that.
Old 07-29-2008, 04:22 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: oil leak
Search for it. All over the internet. Includes diagrams too.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-29-2008, 05:11 PM
Re: oil leak
i found it but alot of people say not to do it why not?
Old 07-29-2008, 05:48 PM
Re: oil leak
Because its not the most accurate way to be doing it and when you do inaccurate tuning then you risk blowing something... In my opinion, a wideband or datelogger is much cheaper than rebuilding a motor.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 03 Corvette Z06
  • 14 Silverado 1500
