ABS Light On
My ABS light has become lit for the past few days. It started off that it would come on once in a while but now is on all the time. I had the codes read for another problem and he told me it was driver side front that had an issue. Last year I had the cable changed as the same thing was happening but now if the cable is new, what else could be giving this problem? I have also read in here about the break light short problem, would this cause the ABS light to come on solid like that?
Thanks, Robby |
Re: ABS Light On
Check brake fluid level and make sure it is around the max level. The infamous short in the rear taillight assembly could be causing this. Check to see that all 3 (top 3rd light, either side) come on when brakes are applied. If one is out, it could just be a bulb out. Check the fuse as well. Usually with the infamous short as was the case in my 97's, your "TCS" dash light also comes on, or your cruise may not as well. Let us know and we can keep trying to solve it for you.
Re: ABS Light On
Thanks for the response.
I will check the status of each light and fluid in the morning. I don't have Cruise so I wont be able to use that for troubleshooting. Which fuse should I concern myself with? |
Re: ABS Light On
Re: ABS Light On
Thanks for that ABS wire info. I checked rear break lights and there were both out so replaced that and also checked fluid level which is well above the sensor location... Perhaps its the wire that cracked as indicated. How easy was it to find where the wire was broke? Did you use a continuity meter or something?
Re: ABS Light On
I have the same kind of problem. ABS and TCS light comes up and disappears. Now the stay on, and I hear a weird noise coming from the drivers side when releasing the brake pedal. Any ideas. Last night my brake failed to work.
Re: ABS Light On
My ABS light came on when my second passenger side hub assembly was going bad. Replaced both originals with a China cheapie from Autozone. After about a year after replacement the ABS TCS light came on, a few months later the bearing on the passenger side started to make road noise, got worse and when I replaced it with a quality Timken unit, the noise and light went away. It is like new again, we will see how the drivers side holds on. I don't know if was just a bad unit or if the install went awry, since the one that went bad was the first one I replaced. Time will tell. By the way, the van has 177,000 miles on it.
Re: ABS Light On
Now you mention it, mine does make some road noise. I though it was a tyre thing, but it could be the bearing. Any way to test if it is the bearing.
Re: ABS Light On
Re: ABS Light On
Re: ABS Light On
Re: ABS Light On
Re: ABS Light On
You'll have to open the tailgate and pull off your rear taillight housing that should be held on by two star head bolts, but I am not sure of the size. If you don't have those sockets, then sometimes a flathead screwdriver of the right size can loosen them if they are not too tight. Once off, you will see a harness with a connector on the end that plugs into the circuit board connector. You can see how GM designed this so that the water flows right into it. Unplug the connector that has about 5 different colored wires as part of the harness and you will see the shorted black wire in the middle of the connector. That's your problem. A shorter way than mine at this point left by another poster was to drill out the burned black wire/connector section and screw in a 10 gauge wire in it's place and connect to the opposing harness ground wire (black one, thicker one). If you prefer my option which costs about $5, proceed with labeling the harness wires that plug into the circuit board as to their location on the mating plug, cut the plug off the harness, attach connectors to each wire, cut down all 4 sides of the circuit bd plug about 3/8ths to 1/2 inch exposing the 5 pins. Be sure to clean off the shorted middle, thin prong/pin carefully. Attach the mating connector from the location markings you did earlier. Test the brakes, notice that your ABS/TCS dash lights are now out (not lit anymore), and apply weatherproof silicone to the connections so that water, etc cannot collect at the harness or connections. If you need further assistance you can email me at [email protected]. |
Re: ABS Light On
Take care. |
Re: ABS Light On
My mechanic tells me it is most likely the ABS wire or sensor which are common on these vans. Are either difficult to replace, I am fairly capable of doing these types of jobs and should be ok to do this. Now with that in mind, if I replace the faulty device, would the error clear or would I have to get them to clear the codes?
