| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Quick Wiring Question
Ok |I am installing my new FAL fans. And now all I need to know is what positive and negative source should I tap them into.
I was considering tapping right infront of the pigtail for the cooling fan but there is four wires there. one is blue with a black line, One is blue with a white line one is black and one is full blue. Which ones should I tap them into? Or is there a better place??
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: Quick Wiring Question
Radiator
------------ White-Black + (Lo) Black - (Lo) White-Blue + (Hi) Blue-Green - (Hi) Condensor ------------ Blue + (Lo) Blue-Black - (Lo) Blue-White + (Hi) Black - (Hi) When installing an aftermarket fan such as a slimline wire the positives together and the negatives together. Example: White-Black \ Blue (+) (slimline) White- Blue / Black \ Black (-) (slimline) Blue-Green /
-Brian
OK So I Should take the white-black and the white and blue solder them together and then solder that to the positive terminal on the fan.
Similarly for the negative two wires. \ Sounds easy enough Thanks Brian
Correct.
No problem man. Just had to do this for mine too, that's why I knew so quickly. lol
-Brian
