HI. I have a 2000 Pontiac GTP. The abs light and tcs off light are on all the time. We had it scanned and were told the code was coming from the left rear speed sensor.Does anyone know where exactly it is located? Is this something that can be fixed on it's own or does the whole hub have to be replaced? This car is getting on my nerves! 2 days ago I was going down the road and the sway bar broke. Had real fun trying to find one of those but finally did. It will be here tomorrow. Replaced one front hub bearing a few months ago. Just had recall for valve cover gasket fixed. I love this car but it is really starting to push my buttons!!!!!
Julie |
Re: left rear wheel speed sensor 2000 GTP
The ABS wheel sensor is located in the hub assembly. Therefore, you have to replace the complete hub. Also, make sure it is not an electrical connector or wiring issue.
I did exactly this for a front hub for a friend. He brought the new hub asm and I replaced it only to find the weatherpack had gotten caught on something and a wire torn loose.
I replaced the hub, resoldered and heat-shrank the wire on the old part so he could have a spare part for the future. A spare hub brg (even if roaring at speed) can make a nice rotary welding positioner if you have such a need in your shop (sort of a lazy susan for continuously welding round parts without a number of stops and starts.) Interestingly the Grand Prix variants have nearly the same front knuckle and hub as the GM-200 "U" vans (minivans)...they share a similar underbody with the U-van obviously being a "stretched" version.
1988 Chevy R-30 1 ton DRW pickup (217k) 1991 Chevy S-10 4WD pickup (192k) 2000 Grand Prix GTP (218k) 2002 GMC Yukon (185k) 2009 G8 - GT (46k) |
Thanks !! Will check it out!!!!
