Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-24-2008, 02:09 PM
87BoxClassic's Avatar
87BoxClassic 87BoxClassic is offline
Radio and Horn not working
1987 caprice classic v-8 305
i just got my car from getting rust repaired and painted but now my horn and radio arent working, i replaced the radio fuse and still nothing. im going to take the head unit out and check to see if the shop broke it. but any other ideas?
is there a fuse box in the engine bay.
Old 07-24-2008, 02:22 PM
Re: Radio and Horn not working
is there a fuse case inside the engine bay?
Old 07-24-2008, 03:17 PM
deesandvees's Avatar
deesandvees deesandvees is offline
The horn's real easy to check at the unit, do that before you take out your radio.
'87 Landau
Old 07-24-2008, 03:27 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
No, there is no fuse or relay box under the hood. The fuse block is against the firewall under the dash, and there is a bulkhead connector on the back of it that passes to the wiring harness under the hood. There is a 10mm head bolt on the connector, in the center, that holds it all together. Take this bolt off and remove the wiring harness connector and then reinstall it all. You might have a corroded connection here.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-24-2008, 03:49 PM
i get on work in 3 hours ill check that.
Old 07-25-2008, 12:59 PM
i figured it out, i replaced every fuse and it worked even tho none of them were blown.
