Old 03-10-2003, 07:07 PM
Carnivore's Avatar
Carnivore Carnivore is offline
Send a message via AIM to Carnivore
Washing the Engine, do's and don'ts
Aight, my engine is looking a lil' dirty, i want to clean it but not with paper towels and other shit, i heard you can take a hose to it from the local car wash or sometihng, but i never see anyone do that. can i put a hose to my engine without harming anything?, what needs to be removed/covered, and most of all is the whole process harmless on the engine?:smoker2:
I love my honda...I hate my honda
Old 03-10-2003, 07:11 PM
Marc-OS's Avatar
Marc-OS Marc-OS is offline
Send a message via ICQ to Marc-OS Send a message via AIM to Marc-OS
here's what you do, go to a store and pick up a can of "foamy engine brite" then pop your hood, cover the airfilter with a plastic bag or something. Then spray the engine down with the engine brite, wait 10-20min, and then wash it off with a hose. After that just run the engine for awhile to get rid of all the water, and bam, you got a clean engine.
Old 03-10-2003, 07:14 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
cover the distributor too
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Cover up the distributor to.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 03-10-2003, 07:16 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Heres what you do .... NOTHING!
Those of you who have seen my engine know it isnt a pretty sight, but me cleaning it isnt gonna make it run better, I change the oil and all that shit regularly, and keep the exterior of my car clean as fuck, so its all gravy.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Carnivore's Avatar
Distributor and Air filter, thats it?, no wiring or anything?, sounds good,e asy enough, i think people are afriad to do this, ie...me
Old 03-10-2003, 07:21 PM
Marc-OS's Avatar
I never even covered up the distributor, i just tried not to spray it directly, and it worked out just fine.
Old 03-10-2003, 07:38 PM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
I also use Foamy engine brite (I don't cover any wires, most all factory wires have sealed connectors) but you should follow the directions and use low pressure water. Good luck.
Old 03-10-2003, 08:15 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
www.1fastrex.com
go here and check out this site, check out the engine detailing section. He's got some badass how-to's. Works GREAT.
Old 03-10-2003, 08:36 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
make sure you either cover up or don't spray on the spark plug wires, My gay Magnecors didn't seal up right and i had to buy new OEM wires cause the Magnecors stopped working.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 03-10-2003, 09:25 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Originally posted by ci5ic
www.1fastrex.com
Good website!
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 03-10-2003, 09:55 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I've never covered up anything, just went to the car wash and sprayed it full blast. Never had any problem with it except when my dizzy cap had some cracks in it, just caused the engine to bogg down some until it dried. Im sure the Engine Bright stuff probably does a better job, but the car wash does a pretty good job.
Oh yea, I have done that several times, quite often actually. About every 3 times i wash my car the engine gets sprayed.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-10-2003, 11:56 PM
toontowncivic's Avatar
toontowncivic toontowncivic is offline
I run a detail shop and you really don't have to worry about anything. All we do is cover the intake if it is after market..(oils and shit) But other than that don't even worry! If you have rust proofing all over your engine..(they like to do this in places like ontario) then use some Varsol aka paint thinner just spray it on and let it sit. we soak the whole engine down with degreaser and varsol and then wipe down the thick thick greasy areas and spray it off with full pressure and tada!!!!! a clean engine!
PS to make it look really sharp pick up some dressing for after it is clean...and don't forget to blow off the engine with high pressure air!
STOLEN!
Old 03-11-2003, 12:45 AM
BullShifter's Avatar
degreaser & pressure washer
small brush
to dress the engine use water based dressing not silicone eventually the rubber will dry out if not appied on a normal basis
leave the engine wet & runnin, mist the water based dressing, close hood & run for 10-15 min, open your hood & WOW pretty. wipe off any remaing water & dressing
silcone dressing are only good for long lasting tire shine & dont let it get on your paint or glass.
The Do's and Don't of power M2wRx04 C/K 0 06-26-2004 11:18 AM
