Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 07-22-2008, 02:23 PM
schusterjo schusterjo is offline
Transmission problems (help diagnose)
Just bought this 99 Durango 5.2L 4X4 with a bad transmission.. The guy I bought it off of said in November (I know we had alot of snow around here last November because I was out riding my snowmobile) they was driving it and heard a loud bang, they then drove it home after the bang and after they parked it the transmission would not work anymore.. That's all the info I could get out of the guy because he was not really a mechanically inclined person..
I know nothing when it comes to transmissions myself.. I can pretty much do anything with an engine but just never had any rebuild/diagnosing experience when it comes to transmissions..
What it is doing
Park
works no need to use blocks
Reverse
you can hear a small clunk like you would if it had a bad u joint...
Drive
only thing is you hear a small sound (very quite) like maybe a pump running or something.. All i can tell you on this is you can hear something is going on.. could be just the torque converter though
2nd 1st
same as drive
I plan on pulling the dust cover and checking out the converter to make sure they didn't just shred the bolts.. this would be my limit to diagnosing a transmission issue lol
Any ideal what it may be or anything that you could suggest for me to check would be greatly appreciated.. If its simple enough (something like replacing converter ext..) I probably just do that myself but if it needs something more then I will just take it to a tranny shop.. I just don't want to get ripped off and charged for a rebuild if it doesn't need it.. I would like to have some ideal what it is because as of right now I have no ideal and a shop will just rip me off more then likely...
Thanks
Jo
Edit:::
I just listened to where the clunk was coming from, had somebody put it into reverse while I was under it.. It is coming from the converter area, so is the quit noise i was talking about.. When i get time I will be pulling dust cover...
Old 07-24-2008, 04:19 PM
Re: Transmission problems (help diagnose)
Here are pics of whats in the pan....
Old 07-28-2008, 10:35 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The pics are fuzzy, but two things I see:
1) The residual fluid looks brown and opaque, meaning it wasn't changed at the proper intervals, if at all.
2) I see some larger angular pieces of debris, which to me are the indications of broken gear teeth. There's quite a bit of larger than normal pieces too...more shredding. Not being captured by the magnet, I'd guess they were aluminum (more likely) or stainless steel...or they just stayed where they fell into the pan.
Would be nice to know what gear the truck was in when they heard the bang, but my guess would be the 1st gear since they got it home and it doesn't move at all. Sounds like a rebuild to me...or find a junkyard transplant. Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
