Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-21-2008, 08:53 PM
cwlisa69 cwlisa69 is offline
02 Saturn Transmission
Working on an 02 Saturn SL2 with a 2 - 3 upshift and 3 - 2 downshift flare. Fluid level good, condition normal. Pressure control solenoid code, and intermittent shift timing code present. Found trans wire harness connector burnt at port that controls pcs, replaced connector, still have same problem. But codes are now gone, any suggestions?
Old 07-22-2008, 06:36 PM
RC1488 RC1488 is offline
Re: 02 Saturn Transmission
Possibly a new pressure control soleniod may be the answer. I would replace it while replacing and tightening the input shaft nut to 111 ft/lbs.
Any reverse slam? Last fluid and filter change? (should be every 10k-15k miles)
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
