Old 07-21-2008, 05:50 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
any axles from other years/cars that will fit?
This has probably been covered, but I couldn't find it, so I was hoping someone knew... or had a link.... link would be fine.
I have a 89 DX, it needs at least the pass. side axle (boot is ripped, knocking on corners), but could use both.. I'm using the DX tranny and stock hubs.. so what can I use?
Old 07-21-2008, 08:06 PM
readallen readallen is offline
Re: any axles from other years/cars that will fit?
I'm not sure on the interchangability of axles, I search my area and oriellys is the cheapest on new and reman 4 gen axles, new- 57 reman- 49 and life time warranty
Old 07-21-2008, 08:48 PM
same at napa, but if anything else will fit, I can get them free.. I work at a junkyard part-time, they give me parts.
Old 07-21-2008, 08:49 PM
They just don't have any EF's around ATM... so I can't just yank the "right ones" lol
Old 07-21-2008, 09:02 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Unless im mistaken a 5th gen axle should fit?
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-21-2008, 09:10 PM
You're mistaken, unless it's a model-specific thing... DX EG's won't fit, ours are 25 spline at both ends, the EG's are 26 outside/25 inside.
I'll check on other ones tho, since you usually have an idea what you're talking about lol.
Old 07-21-2008, 09:14 PM
FrodoGT's Avatar
I see. It would make sense. But I havent ever heard anything about the splines being different. Dont see why they would be dumb enough to do that.
Current project:
Rio Red 91 hatch.
Old 07-21-2008, 09:22 PM
according to rock auto, there are two types for our cars... 23/25, and ??/26
NiChio makes the ??/26, the desc. is "{Front CV Axle Assembly: Right, 26 tooth outer joint
Remanufactured #06443SH1505RM}"
I'm thinking that I'll have to just grab one from the '95 at the yard (only one that's 5spd) and try it out.. see if it will fit or not.
Side note, even the NiChio part number is different between gens.. but I've seen alot of cases where part number just meant something stupid was changed, like the ring clamp for the boot.
Old 07-21-2008, 09:46 PM
"Well the civic std with the 4 spd and the crx hf with a long geared 5 speed both have the smaller axles. Thats all there is to it. Either you get the right size axle. Or you upgrade the hubs to the larger ones from a civic dx si lx or ex." frodogt
I was wonder - is there a difference in strength, fuel mileage, life expectancy, between the 23 and 26 spline axles and what difference does a solid straight shaft compared to the "bludge in the middle" and are they hollow in the larger diameter section (i'm don't know the name for these different shafts) type shafts
Old 07-21-2008, 09:56 PM
FrodoGT's Avatar
but that was referring to the difference between 4th gen axles..
Current project:
Rio Red 91 hatch.
Old 07-21-2008, 10:30 PM
just cram it in there and lock that nut down - if anybody could make it work , its you
Old 07-24-2008, 09:56 AM
eg.ob eg.ob is offline
wrong, i have 95 dx axles in my circle track crx. they work just fine.
Old 07-24-2008, 03:36 PM
Aight, I'm gonna check them out... I'll let y'all know how they work.
Old 07-24-2008, 05:14 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I was gonna say, Christ, I have used just about any axle I could find laying around when I was at the salvage yard. Very seldom you will run into something that won't work just as long as you stick with the same series. I don't even think Auto or manual makes a difference, I'm pretty sure when I did the auto-5spd swap i reused my axles....but could be mistaken there.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 07-24-2008, 09:10 PM
Thanks for the input Tony... I was waiting for a 'vet with some experience on the forums to chime in with personal experience lol... I'll get the axles free from the yard until I can afford new ones.
