Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-21-2008, 05:48 PM
bonez1369 bonez1369 is offline
Question Fuel Pump?
I have an '01 GMC 2500HD 8.1L and I think my fuel pump might be taking a dump on me...
If the vehicle sits 10+ minutes you have to crank on it for 5-10 seconds before it will start, the fuel system primes when you turn the key on but I believe the check valve in the pump is going out and fuel is leaching back into the gas tank. Please help before I go drop $300 on a new pump.
Old 08-08-2008, 09:20 PM
jd-autotech jd-autotech is offline
Re: Fuel Pump?
sounds more like a fuel pressure regulator located on the drivers side on the fuel rail little chrome mushroom looking thing with a vacuum hose going to it pull the hose if you see any fuel and i mean even moisture change the regultor. trust me it is very very common
Old 08-09-2008, 09:32 AM
maxwedge maxwedge is offline
A990 racer
Re: Fuel Pump?
How about checking the fuel press. first, pinch off the return line if you suspect the regulator, this will test the pump pressure only. 58 psi. min.
