Horn Blasting Spontaneously
Have a 97 Lesabre and the horn has started blasting spontaneously. I arrived home from work the other day and it was sitting in the driveway blasting away. If you press the horn, it goes off, but has since blasted 3 more times. It is a straight blast and never stops. Anyone encounter this? Today, it was somewhat difficult to get it to stop. Where is the horn located under the hood? It may have something to do with the recent heat we are having.
Re: Horn Blasting Spontaneously
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Thanks. Is that switch difficult to replace? I can probably do it. I imagine disconnecting the battery is the first step. Then, it appears the pad with the switch should lift off the top of the airbag-I would think. They ought to have horn switches at the salavage yards by the handful.
I wish it were that simple, the problem is; the horn switches are an integral part of the air bag assembly and cannot be replaced. You will need to replace the whole assembly.
Click Here for more info.
you dont want that in your face with out something to hold the airbag back would really suck to get hit with the metal bracket on the back of the bag assembly happy tinkering |
Thanks for the pointers. I have not done anything to the horn (yet) as it has stopped blasting spontaneously. If it starts doing it again, I will do something to fix it.
Hope this message will post as my last 3 or 4 postings to this board have not gone through. |
Quick reply or Advanced reply. We have been experiencing database and posting issues for the last week so please bear with us.
