Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-20-2008, 01:50 PM
tjsw tjsw is offline
2000 towncar..brakes lights don't function
the fuse is fine but none of the brake lights go on...have replaced the brake light switch but that did not solve the problem
Old 07-22-2008, 01:56 AM
Towncar's Avatar
Towncar Towncar is offline
Re: 2000 towncar..brakes lights don't function
First, test the fuses with a meter or test lamp. 20A Fuse #10 & 20A Fuse #22.
We do this kind of diagnosis allot and many times the OP comes back with.. "thanks for the million suggestions, I finally tested that good fuse, it was bad"
Next, verify the bulbs are actually working, yes they could all be blown. The High-mount (3rd brake light) bulbs need testing too.
Here's the detailed, step by step diagnosis procedure:
http://www.keepandshare.com/doc/view.php?id=704518&da=y
EDIT:
Sorry, I just noticed I hadn't made that link 'public'; it's fixed now. My Firefox doesn't like it, but IE does
-Steven
1996 Town Car, Cartier
Old 07-22-2008, 08:42 PM
Hungrycat7's Avatar
Hungrycat7 Hungrycat7 is offline
While you are digging around back there I would check all the wiring to the lamps to ensure there are no brakes or frays.
Old 07-31-2008, 09:48 AM
danielsatur danielsatur is offline
All Brake lights are design in parallel and sharing 12volts.
If a light bulb go's bad replace ASAP,or the others will follow!
Just like a head light when it go's out,the other will get brighter and
burn premature.
MCGIVER
