Old 07-20-2008, 12:56 PM
vohrajtnk vohrajtnk is offline
98 grand caravan ac clutch won't engage
I have been trying to troubleshoot the AC for past week. The system has been vaccumed,charged and checked for leaks. The clutch will not engage i can jump it at the relay and it will come on. I have checked the relays and fuses they all look ok. It won't pass the cool down test and the ac and rec light are flashing constantly( which is probably because the compressor is not kicking in to cool down). Any ideas!!!!!!!!!!!
Old 07-20-2008, 09:26 PM
protusile's Avatar
protusile protusile is offline
Re: 98 grand caravan ac clutch won't engage
You will have to track the electrical problem down. Take it step by step. Check for continunity and voltage at each switch.
The process for the magnetic clutch to engage is:
Ignition switch - on
Blower switch - on
A/C switch -on
Low Pressure switch - on
Thermistor supplies signal of evaporator to A/C amplifier
VSV - on
A/C Compressor Clutch - On
Old 07-20-2008, 11:27 PM
jpb53 jpb53 is offline
I bumped a post I put up for people who were having problems with rad fans and a/c ctuch engagement. Title is radiator fan and a/c pressure tranducer. The transducer is tapped into the high pressure line of your a/c system; that is the line from the compressor to the condenser. The pcm controls compressor engagement. Hopefully this will help. Just an educated guess but more than likely the transducer is probably bad based on what you have posted.
Old 07-21-2008, 07:18 PM
Checked the voltage getting 5v from pcm signall is 1.6 - 2v.
Old 07-21-2008, 07:21 PM
checked voltage getting 5v from pcm
Signal 1.6 - 2.0 v
Old 07-26-2008, 10:03 AM
changed the ac/heater control panel clutch kicked in working great. Thanks for the help.
