Old 07-20-2008, 04:47 AM
rockinanko's Avatar
rockinanko rockinanko is offline
1/24 Honda V-tec B16A engine for EF9
Hi, anyone knows where to get this engine plastic or resin?
or rather any vtec engine series for sale?
i'm doing a EF9 civic mod & hope to put an engine in.
just a simple project to rest my mind...
please advise & thankx!
I can feel the adredalin,
the same adredalin of what it's like...
to be a classic ferrari coachbuilder.
Old 07-20-2008, 07:05 AM
rod_k2's Avatar
rod_k2 rod_k2 is offline
Send a message via MSN to rod_k2
Re: 1/24 Honda V-tec B16A engine for EF9
Revell did a 1/25 Engine... It MIGHT not look too undersized to a Tamiya EF9!
But if you want to go CRAZY CRAZY,you can sacrifice a Tamiya NSX engine...
I was planning to do that someday,since the lack of revell kits in Japan,but I found a gentle [And patient ] person who'd send me two revell kits!
I might do that in the future... Oh,and there is a RARE sakatsu [?] F20C for the tamiya S2000. If you find one,and be insane enough to mod it until it's a B16,good luck!
EDIT: I was thinking... I'm a No-Corolla guy,but I don't consider AE86's as Corollas,so... There is a Aoshima AE86 with engine out there,you can try matching the block to the oil pan existent on the chassis!
"Oh noez,it has more stickers than me! And a wing too!
Old 07-20-2008, 02:50 PM
kaho's Avatar
kaho kaho is offline
Revell is the best bet for engine. Perhaps the B18_ from their integra is a bit bigger, which will make up for the 1/25 shrunken size when you are trying to remodel a 1/24 car with B16A. If you are looking for a simple project to rest your mind, I suggest leaving the model curbside. Focusing to remake the rear end should be quite an intensive job already.
Can't wait to see the WIP thread from you!
Old 07-20-2008, 07:19 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Wow.
So, what kit are you using for the EF chassis? Are you modifying a Fujimi CRX to a hatch? I only know of one EF kit and it is an impossible to find resin transkit for said CRX model.
The only option for a motor aside from scratchbuilding it is the engine in the Revell kits. This will be undersized in a 1:24 model, though, and the B18 in the Integra is definitely not any bigger than the B16 in the Civic, in scale or in real life. Using the Sakatsu engine or the NSX engine as donors wouldn't really work, either, because they are so very different from the B series engines. You might as well be scratchbuilding for all the modification you'll be doing.
Old 07-21-2008, 03:00 AM
rockinanko's Avatar
well, come to think of it...since this is meant to be a casual build, ok i'll do it curbside then...
thankx all, watch my WIP build ok!
Old 07-21-2008, 04:02 AM
kaho's Avatar
Originally Posted by willimo
Wow.
I learn something new everyday
Old 07-27-2008, 01:01 AM
ATMDC's Avatar
ATMDC ATMDC is offline
actually i think the b18 is a bit taller, hence the reason you can put a b18 header on a b16 crx because it will sit to low and hit the ground every bump. ask me how i know lol
Old 07-28-2008, 01:04 PM
rockinanko's Avatar
Since the engine issue is more or less settled, i was wondering of someone could spare me 2 metal transfer honda logos & a civic decal for my EF build...
as i work on ferraris all this while, i don't have any other makes' parts in my stash.
i hope someone can help me on this.
thankx in advance!
