Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-19-2008, 07:48 PM
robzone0911 robzone0911 is offline
94 SE stalling need help
1994 Bonneville SE 3.8L (non-supercharged) 112000mi
First off, I'll start by saying I don't believe this is a mechanical problem. I believe it is electrical. I have searched a few threads and come up with possible TPS problems or EGR problems, but I wanted to put my issue out there and see how the responses compare to what I found. These are the symptoms:
When driving or sitting, occasionally the vehicle chime will rapidly ring 3 times and the speedometer will jump approximately 25-30MPH and return to the actual speed I am traveling, also the tach will jump approximately 2000-3000 RPM. Sometimes if I am not on the throttle while driving the car will die causing me to come to a stop, put it in park, and restart the engine. The SES light will sometimes stay on from startup to the next time I turn the car off, and sometimes it doesn't come on at all.
Today I replaced the spark plugs, cleaned the MAF, replaced the air filter, changed the trans fluid filter, and changed the oil.
While driving the car runs relatively strong, and still gets fairly decent mileage. My best guess would be TPS or VSS. Any input is appreciated. Thanks in advance.
1...2...3...go! 16.3@85mph 2001 Cavalier Z24 Happily traded for my Z32
Old 07-19-2008, 09:07 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 94 SE stalling need help
Three possibilities exist here, it could be the CKPS, ICM, or corroded battery terminals. The VSS, or TPS will not cause an engine that is running to stall! Remove the ICM and check for corrosion under the mount. Also check all grounds under the ICM and fender well!
Old 07-20-2008, 07:02 PM
Ok, well today I replaced the CKPS, and I cleaned the ICM, and each of the coilpacks. Then I took it for a test drive, and it is still doing the same thing. It does it more frequently at low speeds than at high speeds and it's very annoying.
Old 07-28-2008, 03:57 PM
Jrs3800 Jrs3800 is offline
There is a possibility that the PCM may be going belly up on you..
Old 07-31-2008, 04:16 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with HotZ28, that the battery cables and engine ground straps need to be checked (since you replaced the other parts he mentioned). It could also be a corroded underhood fuse/relay center or PCM.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-31-2008, 04:45 PM
inafogg inafogg is offline
have you scanned for codes??
Old 09-17-2008, 05:37 PM
i don't know how to scan for codes on this car I am confused by the write ups also.
