Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-19-2008, 04:53 PM
kaiscape kaiscape is offline
Pls. help. '97 Jetta Low Oil Pressure
I have a '97 Jetta that sat without starting for about 6 mo. I tried starting it the other day and the oil pressure light wont go off. Checked oil level and it's good. It ran with no problems before the lay off. Is the oil pumped seized after sitting? If so how do I get it going? Thnx.
Old 07-30-2008, 09:51 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Pls. help. '97 Jetta Low Oil Pressure
If the engine is ticking bad, replace the oil pump.
If not replace the oil pressure switches (1 on driver side of cylinder head and another above oil filter on housing)
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-04-2008, 03:28 PM
Yea, it's def. ticking... So what do you think happened? The oil-pump that was working just fine got gummed-up and froze from sittnig too long? Bummer to have to replace it. I was just gonna sell it.
Old 08-05-2008, 08:11 PM
VDUBMAN
The lifters are probably dry from sitting for so long. If the oil pressure is fine at idle let the car run at idle for 45min or untill the clacking resides.
