Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-19-2008, 01:49 PM
bigdaddyc bigdaddyc is offline
revs at idle
I have a 95 eagle talon turbo, when you first start it, it revs to 3000 rpms for about 15 secs then back to normal. when you restart the engine it revs from 800 rpms to 2500 rpms in short cycles. please help !
Old 07-19-2008, 10:53 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: revs at idle
You may have one of the 3 following things to blame:
Malfunctioning Fast idle air valve(FIAV)
Malfunctioning Idle Air controller(ISC)
A decent size vacuum leak
Check for loose or broken vac hoses and buy a haynes manual to see how to check your ISC.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 07-19-2008, 10:57 PM
Testiklees
Re: revs at idle
Tim
1990 Talon AWD
PTE SCM5031
