Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 07-19-2008, 12:43 PM
mhedrick_2000 mhedrick_2000 is offline
1999 Jeep Wrangler REVVING
After changing out the exhaust manifold, the engine will rev at start and continue to rev until I shut the engine off (before it redlines). Any help would be great.
Mike
Old 07-20-2008, 06:20 AM
gtmud gtmud is offline
Re: 1999 Jeep Wrangler REVVING
Sounds like you might have a vac leak at the manifold ( intake). Double check and makesure everything is connected. If it ran good before you started, you might have forgotten a hose or something.
Old 07-21-2008, 01:30 AM
soldierp89's Avatar
soldierp89 soldierp89 is offline
make sure that the throttle cable coming through the firewall isnt hung up and that the throttle body is closed. if that is sitting fully opened then that will cause it to redline quick at start up. sounds stupid but could happen.
89' YJ / 95' YJ / 94' XJ
4.2 L I6 / 2.5 L I4 / 4.0 L I6 HO
5 Spd. AX 15 / 5 Spd. AX 5 / AW4 3 Spd. W/ OD
4" Rough Country / 4" Pro Comp
Mickey Thompson 33/11.50/R16
BFG Mud Terrain 33/12.50/R15
Old 07-21-2008, 09:39 AM
tomvid tomvid is offline
When I swapped mine out I had to replace the Idle Air Control Valve also. It wasnt revving as hard as yours but it would rev up to about three grand.
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
