Old 07-19-2008, 08:44 AM
Veyron's Avatar
Veyron Veyron is offline
Fujimi's new brake engineering = FAIL
In assembling Fujimi's F430 Scuderia I've decided I don't like their way of separating the calipers from the rotors.
You can see on the instruction pic how there is a back half of the caliper made onto a hanger/hub part. Next the rotor is installed then the outer half of the caliper. Firstly there is a razor thin surface in which to glue the two caliper halves together; secondly there's almost no tolerance between the caliper and rotor. The rear ones seem to be worse than the front.
It's designed so the rotor wheel turn with the wheel just like a real car. I never build my models so that they roll...even so the assembly is fiddly and barely adequate.
Once the wheel is on it hides the potentially messy caliper joint so it looks fine once all in place.
On one hand it makes painting easier with all the parts separate but I never had a problem with the one piece previous design and in the end the one piece units take less time to paint/assemble.
Old 07-19-2008, 01:28 PM
nicecar's Avatar
nicecar nicecar is offline
Re: Fujimi's new brake engineering = FAIL
All my models are static, so that seems unnessecarily fiddly to me.
Thanks for the info!
I'm the kind of guy who appreciates a fine body regardless of the make.
Old 07-19-2008, 01:55 PM
ZoomZoomMX-5's Avatar
Yeah yeah yeah...at least it's a visible part, not something that gets covered up. It's kind of a damned if you do, damned if you don't kind of deal. I think it plays to the guys that want more detail, but if it's fiddly it's gonna PO the people who like it simpler. I like it because I can paint the caliper separately; no PE disc needed, I could care less if the wheels rotate.
My Fotki Album
Old 07-19-2008, 03:45 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
It's actually a terrific feature for anyone who wants to put in a set of PE sandwich rotors. (I'm sure Crazy Modeler has or will make a set for this kit). It saves the nasty surgery of having to cut off the caliper and hollow it out. But for an out of the box design it's overcomplicated.
Should kits be designed to make it easier to accomodate aftermarket parts...? There's a bit of a philosophical question.
PHOTOBUCKET SUCKS
Old 07-19-2008, 05:08 PM
Mojo_stevo's Avatar
Mojo_stevo Mojo_stevo is offline
Hmm. Seems like something that should have been utilized on a larger scale model. Or at least offered as a option, so if you want to use the traditional style you can.
Old 07-19-2008, 05:41 PM
Lownslow's Avatar
Lownslow Lownslow is offline
i thought this thread was about a car rolling off a shelf
Old 07-19-2008, 08:39 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Ship modelers always deal with small bonding surface, so I don't see why car modelers can't.
BTW, Fujimi just announced the release of its own Scuderia PE set for a whopping price tag of 2520 yen! (along with the one for 250 GTO for the same price). Looks like no DX version this time.
Hiroaki Fukuda
Old 07-20-2008, 08:38 AM
BVC500 BVC500 is offline
Well, the DX versions were a steal. I got my DX Lexus LS600hL for a lot cheaper than buying the kit and the same KA set separately. Fujimi might have realized this.
I like separate calipers. So much easier to paint now.
Old 07-20-2008, 09:05 AM
jano11 jano11 is offline
I think it was a great idea from Fujimi to make the separate calipers along with the rotating brake discs.
Sure, it can be improved, and I think it will be improved.
Old 07-20-2008, 09:28 AM
Veyron's Avatar
Just discovered something else about the Scud kit.
Fujimi supplies window masks but the mask sheet is not pre-cut it's just lines printed on the material...both my kits are this way. I'm hoping Fuji intended to cut them but the process never happened due to a mistake.
If you don't cut the masks precisely on the lines the fit will not be good.
Old 07-20-2008, 09:42 AM
Ohhhh Fujimi....making much better kits, but still making stupid mistakes. Take the LS600hL, for example, a highly detailed kit, but there's no front footwell room! Fujimi cut it short!
Old 07-20-2008, 02:42 PM
kaho's Avatar
kaho kaho is offline
Many kits have front footwell rooms cut short. Normally the front feet space should go up to 1/4 or 1/3 of the wheel. Consider everything underneath the seats in every model is invisible, I think it's fine for them to cut off the footwell space.
Old 07-20-2008, 03:48 PM
Eric Cole's Avatar
Eric Cole Eric Cole is offline
The Tamiya SC430's I built were the same way, had to cut the window masks myself... Oh well... better than not having them at all.
Eric Cole
Other Model Pictures Here:
http://s5.photobucket.com/albums/y197/justdande/
Old 07-20-2008, 04:49 PM
stevenoble's Avatar
Just checked my Fujimi Scuderia kit that arrived on Friday from HLJ and the window masks are the same as in yours.They look quite a tricky shape to cut as well so it'll take a steady hand to cut them precisely.Seems a shame they aren't pre cut.I wonder if it was a mistake or Fujimi intended it that way?
Steve Noble
