Old 03-10-2003, 01:47 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
4th gen nippondenso alternator
does anyone have any idea how many amps these units are rated at. I've been having problems with my battery draining since i got the new system in. I asked audiobahn how many amps that the amp i'm using draws and they said that it is 50-70 amps continuously. I think that the alternator is rated at about 55 amps, but I'm not sure. The amp also has a VU meter and when i watch it sometimes it'll drop to about 12 volts, so i'll turn it down and it'll charge back up to about 13.5-14 volts, but sometimes it won't charge and keep dropping even when i have everything turned off. When i took it to Napa, the guy that checked it said it was still good so I don't know what's going on anymore......
Empty Pockets Racing Member #1
Old 03-10-2003, 04:47 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the apms for the alt sound about right. Amplifiers are NOT a continous draw like say a set of fog lights. The problem may be that your power wire is too small or has too high of an inductance.
Old 03-10-2003, 08:16 PM
GScivic7's Avatar
uhm, i was asking how many amps the alternator is rated at. I had asked the tech support at Audiobahn how much current the my audiobahn amplifier draws and he said that it was inbetween 50 and 70 amps when being ran continuously or something like that. I'm sure it's not my wire. I have 4 guage ground and power. Maybe it's still restrictive though...I really don't want to go out and buy more wire, 4 gauge is really expensive, and the shop that I got it from cut me a deal because i get all of my accessories from there.
Only charged me $2/ft for power and ground wire, gave me free 50 amp fuse and o-rings, and gave me 11ft of 10gauge speaker wire when I asked for 4, for the same price, probably cause it was the end of the roll.
Old 03-13-2003, 12:45 PM
turbcivic's Avatar
turbcivic turbcivic is offline
They are rated at 60-70 amps, depending on the model car and alt, but on an alt tester they do about 56-65 amps. Honda alts are small but easy to replace.
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 03-14-2003, 08:24 AM
GScivic7's Avatar
it sure as hell isn't easy to take the alt out of my 90 ex. You have to first remove the alt from all of it's mounts, then you have to pull the end of the axle out of the hub and move the axle over so the alternator will drop out from the bottom. You can't pull it out from the top because there isn't any room. And you can't just pull it out form the bottom because the axle and tie rod are in the way. I guess it's not that hard, but it's time consuming.
if they put out about 55-65 amps, then it should be able to handle my amplifier...guess i'm going to just go get a new alt then.
Old 03-14-2003, 01:59 PM
turbcivic's Avatar
No, it is easier then that, remove the alt bracket from the block, only three extra bolts to remove and then pull out part of the splashshield and the alt will come through the side. That is what we do at work in less then 20 min.
Old 03-17-2003, 10:06 AM
GScivic7's Avatar
oh shit, pull it from the side, god damn i didn't even think of that. thanks, that's gonna save me some major time
so, do you know if an alt from a b18a or b16 will work with the mounts?
Old 03-17-2003, 11:36 AM
90EX 90EX is offline
How do you pull off the splashshield without breaking the plastic fasteners that hold it on? I broke a couple of fasteners when I installed my CAI.
Old 03-17-2003, 11:51 AM
turbcivic's Avatar
I used a pick to take out the clips
h23 swap 4th gen civic? 92lude91dx '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-16-2009 11:43 AM
FS: Prelude 4th Gen H23 / Misc 4th/5th Gen Parts gerhard Classifieds 2 09-18-2005 05:26 PM
4th Gen vs 4th gen Nickkzx Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 09-23-2001 09:01 PM
