Old 07-19-2008, 01:10 AM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
high pitch wistle at high boost?
what could cause a high pitch kinda wistle noise on driver side of car? sounds like a boost leak but my boost gauge shows no leak. its not clutch slipping bc i dont smell clutch burning, could it maybe be the clutch hose with the check valve? or would that cause a clutch to slip?
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 07-19-2008, 09:47 AM
Girly VR-4 Girly VR-4 is offline
Re: high pitch wistle at high boost?
Either your stock BOV is leaking, or if you have an open air intake, you may just be hearing the turbos spooling now.
www.groundzeroperformance.com
www.3swarehouse.com
1991 Stealth R/T Twin Turbo... sitting...
1996 Orchid Pearl Stealth R/T.... daily driver duty, 275k+ miles and counting!
1995 3000GT Spyder SL... being modified...
Old 07-19-2008, 09:52 AM
Hans_GZP Hans_GZP is offline
Make sure your brake and clutch booster lines are put on the right way. A lot of people end up putting the clutch booster line on backwards and it will cause a high pitched noise when you get into boost above 7 psi or so.
94 Dodge Stealth TT
94 Dodge Stealth TT, pearl yellow, for sale
93 3000GT VR4, stock, for sale, red
96 3000GT Spyder SL, black, stock, might sell
97 3000GT VR4: stock, for sale, red
92 Galant VR4: TBE, bunch of crap
95 Montero SR: run stuff over vehicle
Old 07-19-2008, 12:38 PM
cHo's Avatar
cHo cHo is offline
yeah check clutch and brake booster lines..
Old 07-19-2008, 08:49 PM
well if the bov was leaking would my boost gauge show that or not necessarily. and my clutch hose is on the rite way ive never had it off, but ill check connection for tight fit, and its deff not bc of my intake bc ive had it on for a long while and i can hear the turbo noise but its not loud like this.
Old 07-21-2008, 12:23 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
try this.. when driving your car get on in let it build boost and then touch the clutch pedle.. don't push it all the way in.. just like a little bit and see it the sound goes away..
Jason
Old 07-21-2008, 01:32 PM
the bov wouldn't show on the boost gauge. It just can't hold all the pressure, and makes a honking/whistle noise during hard acceleration/boost.
www.3swarehouse.com
Old 07-21-2008, 03:55 PM
Get an intake pressure tester and you won't have to guess where the noise is coming from
94 Dodge Stealth TT
