Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-18-2008, 12:42 PM
bloomsdayfan bloomsdayfan is offline
alarm going crazy
the keyless entry battery went dead about a month ago, so I've been unlocking/locking doors manually. A week ago I unlocked the door and the factory alarm went off with no way to turn it off other than remove the horn fuse. I unhooked the positive terminal from the battery for about 5 minutes to see if that would reset things to no avail. Is there something I can do to reset the car to a "normal" state so I can reprogram the transmitter with the new battery, or is this even a keyless entry problem?
Old 07-21-2008, 04:04 PM
JabbaTHutt JabbaTHutt is offline
Re: alarm going crazy
Put the new battery in and use it. the programming in the remote doesn't change so the van should see the remote once you install the new battery.
2003 Montana EXT
Most options
Niagara Falls
Canada
Old 07-21-2008, 06:28 PM
I'll give it a shot and let you know. Thanks for the advice.
