Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 10-18-2001, 01:18 AM
Russ Russ is offline
97' 328is- can i use 17x8 whls w/o mod?
Hello,
I have a 97' 328is with the stock 225/50-16 tires and wheels.
Can I upgrade to a rim rim size of 17x8 without modifications?
Thanks,
Russ
Old 10-18-2001, 03:29 PM
328isRob 328isRob is offline
Send a message via AIM to 328isRob
Yes
Old 10-18-2001, 03:40 PM
tach changes if I upgrade to 17x8?
Hello,
Thanks for your response! What about my tach, will that chage?
Russ
Old 10-19-2001, 09:01 PM
bjchacha bjchacha is offline
Your tach shows engine speed - has nothing to do with wheels and tires. Your speedometer will be off unless you mount tires with the same circumference (i.e. lower profile) on the bigger wheels. A wheel/tire dealer should be able to help with this.
Old 10-19-2001, 10:26 PM
Thanks. I spoke to a BMW service tech today. He said changing to a taller tire will not give me the same handling, even with the sport package. I can go wide without effect. Can anybodyconfirm this?
Old 10-20-2001, 03:01 PM
A 17 inch tire will raise the car 1/2 inch... but the HR suspension kit... which is very nice too will lower the car back down.... don't worry about the handeling you'll hardly notice it.
Old 10-20-2001, 03:40 PM
HR kit specs?
Hey Rob,
Okay. What does the HR kit comprise of. Boes replace alot of the OEM parts? Is it expensive? Big install?
Old 10-20-2001, 05:43 PM
Just a new set of springs and struts... There are many different combonations to get H&R springs, Billenstien Struts are the best combo.. or most popular... many other manufacturers make the stuff to. Check out www.bavauto.com Springs and struts can run 700-800. Installation isn't that hard from what I've heard. Get the 17" rims then later get the suspension...
94' 325 cabrio or 97' 328i hi-line sedan bimmerskickass2 3 Series 1 05-26-2004 03:50 PM
97' E36, 17x8.5 too wide? Mods? Russ 3 Series 1 11-13-2001 10:04 PM
Any gearbasket mods so can use sunroof and not look stupid? chrismoose Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 07-12-2001 03:53 PM
