Old 07-18-2008, 12:43 AM
d_crosson d_crosson is offline
Audio Problems
I have three amps hooked up to a capacitor and for some reason right now, whenever i turn my stereo on there is static in the speakers and when you close the door or flash the headlights you hear a sound in the speaker. When the stereo gets turned off there is a noise as well, any ideas what could cause this problem.
Old 07-18-2008, 12:27 PM
JAMZ87SS's Avatar
JAMZ87SS JAMZ87SS is offline
Re: Audio Problems
Sounds like a bad ground to me. I would definately start looking over all your grounds and make sure they are solid.
Old 07-18-2008, 01:56 PM
Re: Audio Problems
I checked all of the grounds again and again, they seem to be all good, i have them hooked up to some bolts on the frame. I have also gone through the connections to each amp to make sure they are good and they are?
Old 07-19-2008, 03:49 PM
doctorhrdware doctorhrdware is offline
Re: Audio Problems
Check the ground resistance, with a DVM, should be zero or as close to zero it can be.
Old 07-21-2008, 01:30 AM
Re: Audio Problems
It was the actual deck, i bought a new one hooked it into the same wiring harness and it does not do it anymore. Thanks for the help anyways.
