Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-17-2008, 11:12 PM
Mustangmom Mustangmom is offline
Angry 1997 Ford Mustang won't start!!
I know it's not the starter! I had the plugs replaced and the fuel filter replaced as well! Now I think it could be either the cam or crank sensor?? I am not sure! This car is getting gas but not sure about fire!! HELP!
Old 07-24-2008, 07:28 PM
goretex goretex is offline
Re: 1997 Ford Mustang won't start!!
does the starter even turn the engine? can you hear the solenoid clicking?
did run before this happened.
Old 07-24-2008, 08:24 PM
rhandwor rhandwor is offline
Pull the main air nozzel at the intake spray some starting fluid in it if it starts its a fuel problem.
Pull a spark plug ground the plug and check for spark if you have spark its a fuel problem.
If you have no spark check the crankshaft position sensor.
