Old 07-17-2008, 10:53 AM
imwanted imwanted is offline
1995 Honda civic hatchback styling kit?
Hi im planning on making a model kit om my friends car. he isnt done yet but i got som pic of the kit on the car. i wondered if there is any kit that got thisk styling or how much would it cost to get someone to make it.
and do someone know if its any PE set for this kit?
im going to start with this kit:
http://www.dump.no/files/d7552d5ee75d/7000_1.JPG
and this is a couple of pic of the styling i need:
http://dump.no/files/d7552d5ee75d/n5...68144_7835.jpg
http://dump.no/files/d7552d5ee75d/n5...24644_2443.jpg
i have no experience with putty so would be nice if there is a kit with this styling that can go with a little fitting. or iv any of you realy good modelers here would make it for me against payment.
its only the wite parts on the car i need.
hope anyone can help me.
Old 07-18-2008, 07:16 AM
Re: 1995 Honda civic hatchback styling kit?
Nobody that can give me a little help?
if i need to do the modds myself could you help me with what putty materials and tools i would need for doing this. prefer links.
also if anyone got a good guide to puttying fenders
Old 07-25-2008, 03:09 AM
anyone got a guide or anything that can help me?
Old 07-25-2008, 05:15 AM
rockinanko's Avatar
rockinanko rockinanko is offline
humm, i'm afraid there won't be much help on this from AF unless someone is also doing the same bodykit mod for his/her build. maybe then maybe there's a chance a copy is obtainable...
actually you can scratchbuild this by yourself but you have to be good in styrene, putty & CA glue experiences.
i think it's either you KIV this build & train start training on something scrap or look around in the web for some resin cast sets, fingers crossed.
trust me, it won't be cheap even if you locate one such bodykit. and the best solution (to me) is do it by yourself. i'm currently doing a 91' CRX conversion into a EF9, so i know the hard work involve in this but the challenge is fun! go to my thread & see for yourself...
try on something scrap first, start asking questions (however stupid ones)& learn now!
cheers!
I can feel the adredalin,
the same adredalin of what it's like...
to be a classic ferrari coachbuilder.
Old 07-25-2008, 06:12 AM
ye but any guide or toturial on how to use putty and how to form and finish it would help as i got no experience with this. i have buyed 2 of this kit in case i dont make it ok on the first one
Old 07-25-2008, 06:49 AM
rockinanko's Avatar
ah, there should be but i don't know where to find them.
anyway, there's really no concrete tutorials or know-how as to what you can do to styrene & putty...how to teach such materials?
i self-taught all these materials by testing & trying them out myself. i get to know their properties, strength & weaknessess by tried & error. there're thousand types of materials out there, what's available to me here may not be the case for you...
here're some things i learn to use in my scratchbuilding;
car putty (cheap)
styrene sheets & rods of many sizes(main dish)
CA glue (flavor)
epoxy putty (strong caster)
all types primer (yes, know all the lacquer, enamel & acrylic properties)
sanding files (i use 240 right up to 12000 grit)
thread cutter (tiny thin cutter)
minisaw (heavy duty cutter)
scale ruler (yes you measure alot!)
p/e templates of various shapes & sizes
copper, aluminium & brass sheets & rods
basically you can use anything you can find anywhere, for scratchbuilding. i've just learnt that those cigarette pack foils can be used as heat shields in modeling...the learning curve never ends here. i uses those drinking straw that has a flexible tube as air ducts for the front brake cooling!
so use your creativity & imaginaton!
this is why i never give up modeling...it gives you brainstorming lessons. you'll end up very sharp & smart in life...
that's all i can tell you, now go & try out everything but experiment on scraps first...not new kits!
Old 07-25-2008, 08:46 AM
mn80228's Avatar
mn80228 mn80228 is offline
There are a couple of tutorials at the top of the forum. There are several in the how-to depository on working with styrene, and there is even a thread in there somewhere about building a body kit posted by R-Tuned, that I have used in the past.
I would start there.
