Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 07-17-2008, 09:28 AM
bluefever bluefever is offline
considering an aztek
considering an 03 aztek with 74,000 on it,problem is the antilock light and awd disable light are on and there's no owners manual in it to tell me why it's disabling the awd,can anyone out there tell me why it would?
Old 07-17-2008, 10:49 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: considering an aztek
Could be something as simple as a tire really low on air, but most likely not. A dealor scanner would suggest replaement of partucular wheel sensor (in this case the whle wheel bearing/hub assenly needs to be replaced), but in many cases the real cause has been been connection to one of those sensors (corrosion, broken wire).
Old 07-17-2008, 01:36 PM
wafrederick wafrederick is offline
Banned
Get it scanned first for codes.Another problem with them are the a/c condensors if this happens down the road later on,they are bolted together with 4 bolts and splits one end.The replacements have three bolt holes and have to get a special clip from the dealer.
Old 07-18-2008, 11:48 AM
well,took it to my mechanic,he put it up on the lift and said it's the right rear wheel bearing hub assembly/sensor,$165 for the part.so i applied for the loan,got approved,called insurance to send binder to bank,so should have it home by tonight,monday at the latest
