Old 07-16-2008, 10:02 PM
mynig254 mynig254 is offline
Fuel cut
I have a 90 crx dx i did the zc swap. It runs good but the fuel cut comes on about 3000 rpms..Whats the problem
Old 07-16-2008, 10:39 PM
readallen readallen is offline
Re: Fuel cut
lo siento mucho, mi tener que sentarse el la sombra- hace calor
Old 07-16-2008, 10:54 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Fuel cut
Do you have any check engine lights? sounds like limp mode.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-16-2008, 11:58 PM
Re: Fuel cut
yeah crank angle.
Old 07-16-2008, 11:59 PM
Re: Fuel cut
yeah crank angle
Old 07-17-2008, 12:37 AM
FrodoGT's Avatar
Re: Fuel cut
Thats why. Fix that and youll be better. Did you hook up the sensor on the end of the cam? The zc has a seperate sensor while the others engines have it built into the distributor.
Current project:
Rio Red 91 hatch.
Old 07-17-2008, 01:33 AM
Re: Fuel cut
yea itsweird it wont start with it hooked up but it will run when you put it on but still shuts down at 3000
Old 07-17-2008, 08:47 AM
FrodoGT's Avatar
Re: Fuel cut
Probably have the wires backwards.
Current project:
Rio Red 91 hatch.
