Old 07-16-2008, 08:53 PM
mike2004tct's Avatar
mike2004tct mike2004tct is offline
P1351 causes prk lights/dash lights fuse to blow???
I've been chasing an electrical bug in my '97.
Finally found what was causing iginition modules to burn up (blew 3 in 3 days).
After the 2nd unit blew, I replaced the coil, thinking the secondary shorted to the primary.
When I installed the 3rd unit with the new coil, rotor and cap, it still was missing badly.
That left 1 of 3 things, the distributor, or the cam sensor which is inside the distributor, or the VCM again. I ended up replacing the dist. with a LLT distributor from Auto Zone, as the whole unit was only $25.00 more than a cam sensor alone.
Problem solved (so far, 3 days of driving, no burnt-up module), but on the second day, the truck didn't start initally. So I re-cranked it, and it fired right up, but the SES light came on, and it was a P1351. Truck has run fine since then.
Tonight on the way home from work, I noticed I had no dash lights.
PRK Lights (#3 fuse, 20amp) fuse was blown.
Another coincidences?
It's my opinion, don't take it personal.
'04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC
Old 07-17-2008, 09:38 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: P1351 causes prk lights/dash lights fuse to blow???
Fuse 3 is for.
Headlight switch.
Transfer case.
Under hood light.
Rear washer pump.
For the code 1351
I would get a factory repair manual or all data and go threw the repair flow chart for that code.
MT
MT
Old 07-23-2008, 06:46 AM
Originally Posted by MT-2500
For the code 1351
MT
Another P1351 this morning.
Any body have this flow chart in a text or pdf file they could PM me?
Old 07-24-2008, 06:43 PM
MT-2500's Avatar
AF - Advisor
Check your pm mail box.
MT
MT
Old 07-24-2008, 09:08 PM
MT
Got it.
Thanks.
Old 07-26-2008, 12:38 PM
After running through the Mitchell Repair guide for P1351 codes,
Looks like the VCM took a crap.
This'll be the third unit. 67K miles.
Bummer.
Old 07-26-2008, 02:09 PM
MT-2500's Avatar
AF - Advisor
Bummer.
Not good
But at lest you found the problem.
Have you got one with a liftime warranty?
Good luck
MT
MT
Old 07-26-2008, 08:49 PM
Not good
Good luck
MT
No.
I got a remanufactured unit from Napa. About 3 years ago.
Might have been 1 year warranty.
Napa hardly warranties any of there stuff nowadays.
Used to be Lifetime 5 years back.
Guess they got too many returns.
Old 07-27-2008, 08:50 AM
MT-2500's Avatar
AF - Advisor
No.
In my area Napa stores are about gone.
Good luck
MT
Old 08-03-2008, 07:22 PM
y2kblazer y2kblazer is offline
in refering to the VCM is that the "brain box" up on the pass. side wheelwell? I got a 1351 code also..... randomly shuts itself off
Old 08-05-2008, 09:26 PM
Yes it is.
More problems today.
I tried holding off as long as I could before replacing the computer.
Truck wouldn't start yesterday, so I went to Napa and ordered another one.
Put it in today, truck still doesn't start.
Checked the spark, very weak, and irratic on the number 1 plug.
Crap, another pick-up/cam sensor blown.
Took the Distributor out, and back to Autozone for a LLT swap.
Put it in a few minutes ago, started right up.
And BTW, I blew another 20 amp fuse, same one, #3 in the box.
Has PRK LGTS stamped on it, but it controls interior, running lights, and other things.
So, I'm hoping the VCM (which I tracked above to be the problem) fried another Sensor.
I'll let ya'll know in a few weeks again.
Old 08-19-2008, 03:10 PM
ndgely ndgely is offline
This brain box is behind the battery? Also can it be replaced with a brainbox from a different year(96). I can get it from the bone for 50 bucks then over 200 bucks
Old 08-20-2008, 08:15 AM
MT-2500's Avatar
AF - Advisor
Junk yard brains do not work out very good.
The need reprogramed for the truck/car to work right.
MT
MT
