Old 07-16-2008, 04:36 PM
mynig254 mynig254 is offline
Cool Crx Zc Injector problems
Ok so i have a 1990 Crx Dx. I did the DPFI to Mpfi conversion. I ordered the harness made for the conversion. I have the Zc ecu. The car runs on all four cylinders but only if you are spraying starter fluid directly into the intake. None of the injectors are spraying fuel. The fuel pump works. It gets gas all the way to the fuel rail the idk. Any help would be appreciated. I just need to know what you think is wrong.
Old 07-16-2008, 06:32 PM
readallen readallen is offline
Re: Crx Zc Injector problems
are the injectors clicking- maybe low fuel pressure
Old 07-16-2008, 06:42 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
retarded main relay, bad CPS, incorrect injectors, incorrect injector firing order, bad resistor box, FPR stuck open, dirty/clogged injectors, a few other things.
Old 07-16-2008, 06:43 PM
also, check the fuel filter and pressure on the rail.
Old 07-16-2008, 10:26 PM
check the luck sensor, you could be low
Old 07-17-2008, 03:07 AM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
rent or buy an injector test noid light, plug it up, one harness at a time see if it blinks when you try to start it. if not, its your harness. does a zc ecu work w/ the swap?
Old 07-18-2008, 06:36 PM
ZC and Si wiring are the same, less the CPS, which on the ZC is on the second cam, on the Si it's part of the dizzy.
Maybe the plug-in harness still required some wiring to be done by the owner? You should check the directions.. just to make sure.
