Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-16-2008, 09:44 AM
Leader1 Leader1 is offline
Switching Fan Clutch to Electric Fan
I have Envoy 2003, the cooling fan clutch got a problem, then the dealer change it with a heavy duty one. the new one is noisy and makes the car as I feel heavy.
Is it possible to switch the cooling fan to an electric fan? is it better for the car?
I heared the performance get better and the AC also get better, but it takes a lot of power???????????
Thanx
Old 07-16-2008, 10:40 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Switching Fan Clutch to Electric Fan
In general, I have heard it both ways...some say it helps, others say it doesn't.
IMO, if set up correctly, it should help performance of the engine and the A/C at least a little. The engine is not using power to turn the heavy fan and clutch. And when the A/C is running, the electric fan(s) should turn on as well to help cool the condenser (this may require a splice into the A/C clutch circuit). Finally, some fans can be adjusted to turn on at a different temperature than the thermostat (or the thermostat can be replaced with a lower temperature version allowing a slight performance gain), allowing a moving vehicle to naturally cool the coolant and lessening the electrical load.
Some will report that the reduced rotational mass will result in a feeling that the engine revs freer or feels peppier and slight performance improvement. The caveats are that they are sort of expensive for a good setup ($300 to $500) and rarely worth the power gained (3-6 HP), and sometimes require the altenator to be replaced with a heavy duty version to cope with the higher electrical draw.
If you are considering doing this and are not mechanically/electrically inclined, then pay to have it done. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-17-2008, 02:05 PM
Thanks and take care
Old 08-08-2008, 01:54 AM
Jaynet Jaynet is offline
Here you go. Give these guys a call - you may want to send them your PCM as well. Do some reading and research on this. Either way here is a fan kit specifically for the Envoy & Trailblazer trucks.
http://www.pcmforless.com/index.php?...d=74&Itemid=81
