Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 07-16-2008, 09:06 AM
[email protected] moez1010@yahoo.com is offline
Blend door Question
If anyone has a blend door photo showing the top view. I would like to see it
if I may. Please
It looks to be in an open enough area where I might be able to reach up
and seperate the door from the electric activator. I dont know perhaps if I
put it on max cool and give the door a push in the right direction might set it right. Worse case I reach up twice a year and set it manually. Its on max heat or max cool anyway. Slide it over and put a golf ball on it so when
I put it on cool it is time for golf again.
When I reset the car after service it has a default setting. Could that setting be dead center? Then it moves left or right based on request hot or cold?
Old 07-17-2008, 06:47 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: Blend door Question
Here is a picture I took of the module, does that help ?
http://www.cmasalvage.com/93tc_blenddoor_act1.jpg
Mike aka JYD
Old 07-19-2008, 07:02 AM
Thanks. Yes it does. Was hoping that the control arm for door came out the side. Appears to lift off after screws are removed. Good Luck
