Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-16-2008, 09:01 AM
snooz8269 snooz8269 is offline
97 Supreme A/C Clutch problems
Last year 07 I was able to short the low pressure sensor and activate the clutch so I could add freon. This year I did the same thing but the clutch wound not engage. I check the obivous fuses and all are good. The panel switches seem to be working OK. It's has the automatic air settings. IE you have to turn down the temp setting on dash panel
Also the "check engine" light comes on & off occiasionaly.
Everything else in the car works great
Any Idea's
Old 07-16-2008, 09:57 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 97 Supreme A/C Clutch problems
Don't be "shorting" three wire "switches" they are actually pressure transducers- that feed back exact pressure readings to the ECM- you risk frying your computer - if and when you add refrigerant- the pressure when it reaches 47 psi will automatically engage the compressor-- you must have a leak- most likely place is the compressor shaft seal and the compressor case halves-- Good Luck!
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
