Old 07-15-2008, 03:18 PM
302Z28 302Z28 is offline
Vaccum leak?
I have a '97 Cal 2.2 that has had an occasional stumbling problem from idle to just over 1,000 rpm. I have tried several times to locate any vaccum leak, but have not found anything. Yesterday, I noticed that the o-ring was missing from the dipstick cap - oil fill tube. I have not replaced it yet, but was wondering if that could cause a vaccum leak through the PCV valve / crankcase.
Any thoughts?
Thanks
Old 07-15-2008, 07:31 PM
rhandwor rhandwor is offline
Re: Vaccum leak?
Use a can of carb. cleaner spray along the edges of the manifold. Also spray around any other areas where vacuum can leak. If you find a leak the engine will smooth out when the spray hits it.
Old 07-16-2008, 01:06 PM
Spyder3K Spyder3K is offline
Send a message via AIM to Spyder3K Send a message via Yahoo to Spyder3K
Re: Vaccum leak?
Did you take a look at the map sensor or try to tighten down the TB by chance?
1998 Chevrolet Cavalier Z24XR (My Baby)
1991 Toyota MR2
"When you turn your car on, does it return the favor?" -GM
"What just happened?!"
"You just pissed him off! That's what just happened!"
In the words of the Great Fred Baboo, if all else fails, "CHEESE IT."
