Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 07-15-2008, 10:54 AM
scarfaceK scarfaceK is offline
2002Almera 1.5 Oil problem with spark plugs
My Almera started to struggle with acceleration and eventually refused to start. I checked the spark plugs and they had oil on the tip and on the threads. I checked the gaskets round the plugs and they seem fine. I refuse to believe that the pistons or piston rings can be worn on a Nissan this young (2002) so Im going to change the PCV valve on it.
The coils are fine cos I checked the spark plugs and change them to new. The car starts but the plugs come out with oil again. If I run the car, the oil will collect up and stop the plugs from firing again.
Is there anything else that can cause the oil to leak into the combustion chamber and onto spark plugs?
Can anyone help please?
Old 07-17-2008, 03:28 AM
mmcleo11's Avatar
mmcleo11 mmcleo11 is offline
Re: 2002Almera 1.5 Oil problem with spark plugs
Valve seals are commond for leaking if the PCV is blocked. Builds up pressure in the rocker cover and pressurises the seals, which leak oil down the valve and ino the combustion chamber.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
