Old 07-15-2008, 10:51 AM
gobobcats gobobcats is offline
'93 S10 2.7L Blazer won't start
Current is going through the 1st and 2nd spark plugs. There is no spark at the 3rd. So I replaced it, but still got no spark. Replaced the cable, still no spark. Could it be the distributor that I need to replace, or am I way off here? Thanks in advance.
Old 07-15-2008, 11:03 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: '93 S10 2.7L Blazer won't start
Good hot blue spark from coil?
Check dist cap and rotor.
MT
MT
Old 07-15-2008, 11:08 AM
MT
Honestly, I know nothing about this stuff. I know how to check for a spark from the distributor cap with my spark tester, and I am fully capable of changing spark plugs (although they are very difficult to reach in this car).
So what am I checking for on the distributor cap and rotor? Thanks for helping, btw.
Old 07-15-2008, 01:19 PM
MT-2500's Avatar
AF - Advisor
Look for moisture in it and cracks and carbon tracks form a crack.
Also check for dist shaft side play.
Good luck
MT
Old 07-15-2008, 04:37 PM
Thanks. I'll check when I get home. If I do find these problems, does that mean I need to replace the distributor cap, or the entire distributor?
I've taken really good care of this car over the years (only has 120K miles), and only use it for towing a few things (small lumber, ATV, etc). I've always had a repair center take care of everything, but I thought maybe I could start saving some money and do some of the simpler things myself (with help from folks like you on these message boards). If this is too labor intensive to check and fix these things, then I'll have it towed to the repair center down the street. If you think I should be able to do these things myself, then I'll stick with it.
Old 07-15-2008, 04:54 PM
MT-2500's Avatar
AF - Advisor
Replace cap and rotor id bad.
Annd dist if worn out.
Use good AC-Delco cap and rotor.
MT
MT
MT-2500's Avatar
AF - Advisor
MT
MT
Old 07-15-2008, 05:25 PM
MT-2500's Avatar
AF - Advisor
MT
MT
