Old 07-14-2008, 08:56 PM
windstar9908 windstar9908 is offline
99windstar passenger side window
my passenger side power windowdoes not work. no sound when pushing the button. could there be something simple causing this or do I need to replace the motor?
Old 07-15-2008, 07:57 AM
12Ounce 12Ounce is offline
Re: 99windstar passenger side window
I have had to lift up the control button assembly, from the driver's door, remove the swithes ... disassemble, clean and lubricate the little contact switches. Somewhat tedious work ... but it got rid of my "won't move" problems.
Old 07-15-2008, 09:35 AM
northern piper's Avatar
northern piper northern piper is offline
you could also try to activate the switch while jiggling the rubber sleeve between the door and the frame to see if a wire or 2 are chafing. I've had this happen a couple of times.
Piper
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 07-16-2008, 09:47 AM
bulrid8 bulrid8 is offline
I have a 99' that had the same problem. I had power all the way to the motor. I then removed the motor and it worked fine. Put it back in and window worked.
About two months later, same thing happened. pulled out and put back in, it worked again. I think it is either jamming up or has a bad spot on motor. I know leave window down about an inch( have ventvisors) and has not done it yet again.
You cold try this. There is a write up on here, on how to remove the motor. Be ready, it is a PITA job.
Old 07-17-2008, 03:35 AM
tripletdaddy tripletdaddy is offline
It can jamb either wide open or fully closed. Do the inside lights dim any when you try operating it? According to the diagrams I have, there is no relay that is activated every time you use the window switch, so you wouldn't have a click sound from that. The way the motors are wired to provide bi-directional movement, in addition to 12v hot going to the motor all the way from the driver's master control switch, which also provides the power to the passenger's switch, the ground comes all the way from there too. The polarity switches side to change motor direction, so you need to be sure to have both at the motor when checking.
Old 07-17-2008, 06:09 AM
wiswind wiswind is offline
My passenger side window does the same thing on my '96.
I also had the track break......on both the driver's side and the passenger side.
The track that broke was the one that is closest to the latch.....furthest from the door hinge.
You have to remove the inner door panel to get to it......replacement from your FORD dealer, bolts right in.
The spot welds broke on mine.....and the track was laying in the bottom of the door......making a rattle when I went over big bumps.
I have pictures posted that show the inner door panel removal......the track, and how to change the motor (where to drill to get to the bolts).
A link to the pictures is in my signature.
I would try spraying some electronic cleaner into the switches to clean them....as it sounds like the easiest thing to do.
For the passenger side......see if it works on 1 side and not the other.....and indication that it could be a dirty or worn switch contact.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 08-02-2008, 01:39 PM
Lbert Lbert is offline
The best way to diagnose the problem is to remove the door panel. It takes less than 15 minutes to remove the door panel and disconnect wire harness to the window motor. Connect a multimeter and see if you are getting voltage. If you do not get voltage, your problem could be the switch, relay, or fuse. I did a write-up on this, cilck link: http://www.webshots.com/search?query...e=chromeheader
