Old 07-14-2008, 07:44 PM
randywirtzfeld randywirtzfeld is offline
check engine light
I am looking at purchasing a 2001 Chevy Cav. and it has the check engine light on. The owner claims it is related to him changing the oil himself and not being able to reset a oil change interval trip. Is this possible, every other vehicle I have, the oil change light is seperate from the check engine light?
I live in a remote area so nobody scans the codes for free, so I would have to make an appointment at a garage to have the codes read, which I would do before I buy it, but I was wondering if it was even possible, I would think the change oil feature would be a seperate light?
Thanks,
Randy
Old 07-14-2008, 07:56 PM
kwk39018's Avatar
kwk39018 kwk39018 is offline
Re: check engine light
You shouldnt have a oil change light.You have a diffrent issue.Might be a misfire,do to the age it might need a tune up?
It might a pos, but its my pos.
Old 07-16-2008, 02:11 PM
Spyder3K Spyder3K is offline
Send a message via AIM to Spyder3K Send a message via Yahoo to Spyder3K
If you have a check engine light coming up, is there any way you can get that scanned so you can get a better look into the problem? Shit, it could be a huge situation and you could get screwed. Find out what that engine code says before you go any farther. Cuz, seriously, I never heard of that and I've been a cavi owner for 6 years. And believe me, I've had problems you'd have nightmares over. lol
1998 Chevrolet Cavalier Z24XR (My Baby)
1991 Toyota MR2
"When you turn your car on, does it return the favor?" -GM
"What just happened?!"
"You just pissed him off! That's what just happened!"
In the words of the Great Fred Baboo, if all else fails, "CHEESE IT."
Old 07-16-2008, 02:12 PM
I mean I know you said you have to pay for it. But shit, I'd make the owner pay up for it. Some scanners you can buy are relatively cheap nowadays, but I don't trust buying a new car with an engine light on.
1991 Toyota MR2
Old 07-16-2008, 10:13 PM
Jacfourteen Jacfourteen is offline
If you have a walmart anywhere close you could pick up a scanner for about $80-$100, they are pretty handy to have anyways, and they work on anything 96 and up
99 Explorer (my daily driver)
-2" lift, 31" tires
-Magnaflow muffler
-7" Touch screen DVD stereo
-12" drop down LCD monitor
02 Mustang Convertible (wife's)
-K&N Filter
-Flowmaster 50
68 GMC (project)
-300 HP 350
Old 07-17-2008, 10:38 AM
muff34 muff34 is offline
Thanks,
Randy
Never heard of the oil change interval light on the Cavies. Seen it on the more expensive vehicles and you are correct it is a different light /indicator on those vehicles. I could be wrong but I think someone is BS ing you about cause of light. Have him pull out the owners manual and show you where it tells you about "oil Change interval light"
Life Is A Highway ,Enjoy The Ride
Old 08-27-2008, 03:20 PM
Zeifer Zeifer is offline
The only light related to oil on a Cavy is the low oil pressure light. He's a liar. :P
Old 08-27-2008, 04:37 PM
Jason/RKBA's Avatar
Jason/RKBA Jason/RKBA is offline
I seriously question this guys character and morals. Run...far and fast!
Old 08-31-2008, 12:40 PM
I highly recommend picking up a scanner, they are an invaluable tool with newer cars.
Old 09-04-2008, 03:00 PM
jamesbeeby99 jamesbeeby99 is offline
I'm having nightmares from problems with my 1997 Z-24 which is mechanically identical to your '98. The engine stumbles and quits when stopped in heavy traffic on hot days. Restarts okay, but takes 2500 rpm to keep it running. On the freeway I get a massive stumble with the tach dropping and then power returns to normal. The stumble usually happens twice and the MIL lights for both crank and cam position sensors. Most engine sensors and ignition components have been replaced with no help. Was this one of your nightmare problems? If so, what fixed it?
