Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 07-14-2008, 04:02 PM
joe265 joe265 is offline
99 venture sick
I had the intake manifold gasket replaced about 30,000 miles ago, recently had gas tank replaced also. Yesterday the wife started the vehicle , she noticed it running rough and the service engine light was on. She made it home, she said the low coolant light came on briefly, this morning I started it up light was still on still running bad , it has coolant. was going to take to autozone to have code checked, wife noticed white smoke as she was leaving the driveway, she stopped the van and killed it , then it wouldnt start up again, acted as if battery cable was loose.I got it to start ,drove it back down the driveway, it was running really bad with white smoke coming out of exhaust. Checked gas cap, air filter ,can't find anything obvious, any help would be appreciated.
Old 07-15-2008, 11:24 AM
pastaben pastaben is offline
Re: 99 venture sick
my 99 Venture had similar symptoms without the white smoke. Turned out it was one of the ignition coils.
PastaBen
2004 Toyota Sienna XLE, 117,000 (since 2010/60K)
2004 Venture ext LS, 108,750 (since 2007/33K)
2004 Toyota Corolla LE, 153,000 (since 2012/150K)
1996 Honda Civic HX, 252,500 (since 2012/222,900)
Old 07-15-2008, 03:27 PM
cjstew4 cjstew4 is offline
Re: 99 venture sick
Very possible it is the blown head gasket. DO NOT DRIVE IT UNTIL IT IS PROPERLY DIAGNOSED. Start it up, and with your hand 3-4 inches away from the tailpipe, are you getting steamy smoke out the back to the point where it burns your hand? If so, its the head gasket needing replacement including machining the heads.
Old 07-15-2008, 08:08 PM
Re: 99 venture sick
I borrowed a code reader from autozone and got code p0301 cylinder 1 misfire detected , now what should I do to troubleshoot this
Old 07-19-2008, 02:54 PM
jmebonner jmebonner is offline
Re: 99 venture sick
I'd check the coils and or plugs. Easy to check. Did you already do as suggested above about the head gasket check?
