1997 jimmy hard to start first thing in am
I have spark, it seems like the fuel line is empty, takes a few cranks first start of the day, i have to keep pumping the gas peddle between tries, starts tries to start, like their is no fuel, then after a min or two it will start to get enough fuel and starts, runs like a top after starting.
If it sits for a few hours or over night it starts all over again. Does it every morning. I replaced the fuel filter and threw in some injector cleaner and still does the same. Any suggestion or ideas ?? |
Re: 1997 jimmy hard to start first thing in am
Check fuel pressure and leakdown rate. Ignition in RUN position, engine off, fuel pressure must be 60psi to 66psi. After 2 to 3 seconds the fuel pump will shut off and fuel pressure must remain above 55psi for 3 to 5 minutes. Post your results and we'll continue with diagnosis.
its probably your fuel pump i had the same exact problem
Before jumping to a conclusion you better do the checks above. Fuel pumps aren't cheap. If you install a fuel pump & it doesn't cure the problem then what?
