Go Back   Automotive Forums Car Chat > Toyota > General Discussion
Old 07-14-2008, 10:39 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Hypermiling techniques and mpg results
The topic of gas mileage is prevalent these days and I'd like to open a thread regarding what techniques people are using to squeeze extra miles out of their tank.
I keep track of my mileage for my commuter '92 Camry. I go abt 70 miles round trip to/from work...50% highway miles, 25% back roads, and 25% city. My baseline was about 26mpg. I rarely use the A/C, then only in the afternoon.
I've started to try a few techniques that those "hypermilers" use to push their cars to the limit and I have to say that there is a difference. I've tried the following:
1) Cruise along in the highest gear possible for as long as possible...that means in O/D and TC locked up...usually at 45 mph and above and light throttle.
2) Shift into neutral and coast down upcoming hills and towards stoplights. I rev the engine up before shifting back into Drive to help minimize slippage and encourage faster TC lock up. I keep my speeds reasonable with the traffic flow...not too fast or too slow.
3) Shut off the engine at longer red lights. I will say that on hills to beware that you'll slowly lose vacuum assist for brakes, so you'll have to press harder to stay put or hold the parking brake.
4) Run the A/C only as long as it takes to cool the cabin down, then turn it off and recirculate the air. The air temp from the registers will stay pretty cool due to the swamp-cooler effect from the condensate that has formed on the evaporator. I use a thermometer to help gauge when it's time to turn it on & off...usually gets uncomfortable above 80 degrees for me.
5) Easy acceleration from red lights and stop signs, especially if there's another one just a block or two away. Why hurry to the next red light?
I do not currently inflate my tires to max sidewall pressure because that promotes uneven tire wear...and rolling resistance is not one of the larger factors. I also noticed an uptick in mileage when I readjusted my timing and cleaned the cap and rotor contacts. As of this writing using these techniques I posted a 30.05 mpg at my last fillup, an improvement of about 15%.
If anyone else has any tidbits they'd like to share, I'm sure we'd all like to hear about it
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-14-2008, 11:34 AM
somick's Avatar
somick somick is offline
Re: Hypermiling techniques and mpg results
A note to # 2: from what I know when you coasting in gear and not giving gas computer shuts injectors down which means no gas; on other hand when in neutral you still need to keep engine rotating which means some gas spent for this.
I do over inflate my tires. Just a tiny bit. 33 from required 29 pounds. I get 33 on highway. City mileage varies. Depending on conditions from 25 to as much as 30.
A note to #3: shutting down your engine is dangerous! Very dangerous! And pennies that you may save on this do not worth and accident and god forbid somebodies life. Plus this is illegal.
My two cents,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 07-14-2008, 02:30 PM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
'Hypermiling' Is Dangerous, Says AAA
Extreme fuel-saving measures can put motorists at risk
read it here ==> http://consumeraffairs.com/news04/20...prices274.html
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 07-16-2008, 10:11 AM
jdmccright's Avatar
The RustBuster
I'll agree that some of the techniques are dangerous and those are ones I do not engage in...coasting with the engine off and drafting to name a few.
Regarding #2, the ECU will feed gas if your foot is off the accelerator whether you're in our out of gear.. in both cases the engine is at idle state. But in gear, the engine is providing braking through the torque converter, so idle fuel rate is being consumed at 2000 rpms versus 750 rpms. In a manual transmission, the effect is the same only more pronounced since there is a direct connection between engine and transmission...no slipping torque converter.
Regarding #3, I find it difficult to see how my vehicle, stopped at a light and engine off, surrounded by other stopped vehicles, could cause a fatal accident. I will reiterate that I have only done so AFTER I have come to a stop. And according to my state's motor vehicle laws, it is not illegal to do so...yours may be different.
Perhaps "hypermiling" wasn't a great word to use for this topic given it's negative connotation, but will hopefully generate good, safe, and economical driving habits.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 07-16-2008, 11:37 AM
somick's Avatar
Iam sorry. I misread your statement. I was referring to coasting with engine off.
Shutting down your engine at a traffic light will probably save you some gas. When I lived in San Jose I specifically timed some traffic lights. Sometimes up to 5 minutes of red. But I still doubt that new/rebuilt starter is worth it.
Regards,
Sam
Old 07-16-2008, 03:45 PM
somick's Avatar
I keep thinking about this statement but unfortunately cannot find any information neither for nor against it. From what I have read at different automotive forums "when your foot is off the accelerator injectors do not get any gas"
Hopefully somebody else will chime in...
Sam
Old 07-19-2008, 10:20 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Most Toyotas will stop injecting gas when your foot is off the accelerator and the rpms are above some specified rpm. This is called the fuel return speed or fuel return rpm.
The fuel return rpm is 1500 rpm in the 5S-FE and some 5VZ-FE ('00 4-Runner), and 1200 rpm in the 1MZ-FE, 3VZ-FE and 5VZ-FE ('03 Tacoma). With a manual transmission, the 5VZ-FE has a fuel return rpm of 1000. You get idle injection below that rpm in these engines. For example, see pages SF-66 and SF-75 of the '99 Camry manual or SF-65 of the '03 Tacoma manual.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
