Old 07-14-2008, 05:22 AM
jrste jrste is offline
winsheild wipers
my wipers stop in the up position when you turn them off. also there is a ticking noise when the are on (coming from inside the dash)
Old 07-14-2008, 06:42 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: winsheild wipers
Verify the grounds are good at the wiper motor. Sounds like an issue with the park circuit. Do they always stop in the same position, or just wherever they're at when you turn them off?
If always in the same location, then it could be that the wiper arms have slipped on the wiper gearbox shaft (due to being turned on when frozen, etc.). The clicking you are hearing could be from them trying to go too far on the windshield and tapping the side trip around the windshield.
-Rod
Old 07-21-2008, 02:29 PM
-Rod
thank you for responding. Everything mechanical is in good working order. they always stop in the up position when you turn them off. all of the functions work properly at each of the intermitent settings(stays in the down position between swipes) low and high settings work well too, But when you turn the switch there is a clicking noise from under the dash?
